how to mount metal heat shield on bumper???
Old Aug 23, 2004 | 04:37 PM
flip1199's Avatar
Default how to mount metal heat shield on bumper???
how do u guys mount metal heat shields on the bumper for exhuast? i don't really want big bolts showing...
Old Aug 23, 2004 | 04:42 PM
Canuk_SiR's Avatar
Default Re: how to mount metal heat shield on bumper??? (flip1199)
try tacking studs to the back of the plate, and drilling holes in the bumper. use some larger washers and bingo, no bolts showing with all that good bolt strength
Old Aug 23, 2004 | 04:53 PM
30psi Teg's Avatar
Default Re: how to mount metal heat shield on bumper??? (Canuk_SiR)
Or just use rivets
Old Aug 23, 2004 | 04:59 PM
flip1199's Avatar
Default Re: how to mount metal heat shield on bumper??? (30psi Teg)
do u have any pics of rivits installed on a car?
Old Aug 23, 2004 | 05:08 PM
99_GS-T's Avatar
It depends on what you are using for the heat shield. If you are using slightly thicker material, some countersunk head rivets of the same material will work and look nice. If the material is thin (.020" or so) button head rivets work well. Use a washer of the same material as the rivets on the back to help spread out the clamping load of the rivets.
Old Aug 23, 2004 | 05:14 PM
30psi Teg's Avatar
Default Re: (99_GS-T)
listen to this guy ^
sorry no pics
Old Aug 23, 2004 | 05:19 PM
flip1199's Avatar
Default Re: (30psi Teg)
i got this pic from africanqueen so are these what i was lookin for?
Old Aug 23, 2004 | 07:19 PM
wantboost's Avatar
Who is Mr Robot?
no, those are foglight covers, you probably want to make one out of aluminum and rivet it on using the small rivets, aluminum will stand up better than the carbon fiber will
Old Aug 23, 2004 | 09:52 PM
30psi Teg's Avatar
Default Re: how to mount metal heat shield on bumper??? (wantboost)
Yea those are the kind of rivets I was talkin about.
You could do the plate out of either sheet aluminum or stainless and then they make the rivets in stainless or aluminum so just match em to what you use.
Old Aug 23, 2004 | 11:31 PM
flip1199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">no, those are foglight covers, you probably want to make one out of aluminum and rivet it on using the small rivets, aluminum will stand up better than the carbon fiber will</TD></TR></TABLE>
yea i know those are fog light covers, i was talkin bout the things holdin up the fog light cover. i'm using 18 gauge sheet metal for mine...
Old Aug 24, 2004 | 06:34 AM
AllMoToRB18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psi Teg &raquo;</TD></TR><TR><TD CLASS="quote">Or just use rivets</TD></TR></TABLE>
Old Aug 28, 2004 | 12:25 AM
flip1199's Avatar
Default Re: how to mount metal heat shield on bumper??? (AllMoToRB18c)
does anybody have pics of what the back side of the rivit looks like installed?
Old Aug 28, 2004 | 07:15 AM
wantboost's Avatar
Who is Mr Robot?
you mean the side you dont see? it looks like a little ball with a point sticking out of it
Old Aug 28, 2004 | 04:56 PM
flip1199's Avatar
oh ok thanks, because at my work i saw some sheet metal with rivits in it and the back looked butterflyed out, kinda like a flower in a 1in diameter.
boostedb20z
Oct 6, 2009 12:00 PM
Hondatuner88
Welding / Fabrication
13
Oct 8, 2006 06:54 AM
MurdersV8s
Sep 5, 2006 04:45 PM
rota power
Jun 11, 2006 06:36 PM
1 point 6
Feb 2, 2005 11:26 AM
