Cast iron turbo manifold. Weld it.
Old Aug 23, 2004 | 02:23 PM
gtcali's Avatar
Default Cast iron turbo manifold. Weld it.
I have a hairline crack in my Rev Hard manifold. Can I get it welded? If so what is the best way? Would it be better just get a new manifold?
Old Aug 23, 2004 | 03:20 PM
david@didrace.com's Avatar
Default Re: Cast iron turbo manifold. Weld it. (gtcali)
The problem with welding cast iron is that it cracks if not uniformly heated/cooled.
1. Prepare weld (drill past the ends of the crack with 1/8" bit, bevel/gouge crack, clean).
2. Preheat to at least 1000* F.
3. Weld.
4. Postheat.
Old Aug 23, 2004 | 03:35 PM
Canuk_SiR's Avatar
yes you can weld cast iron. you'll have to do the steps described above, and also use a high nickel rod. stainless rods work good too on cast
s.cha
May 11, 2009 08:44 PM
lkailburn
Welding / Fabrication
Jul 31, 2005 11:57 AM
egturbo
Jun 13, 2004 07:06 PM
Patron
14
Dec 9, 2003 01:34 PM
TurBoXBirD16
May 7, 2003 01:20 PM
