Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
No brake boost after putting around for a bit
Old Aug 23, 2004 | 09:53 AM
turbohappy's Avatar
Default No brake boost after putting around for a bit
I've had this problem on my '89 CRX for a while now. If I drive really slow for a little bit, I lose brake boost (I assume that's what's happening, the pedal drops almost to the floor and then is really hard but does do something). Doesn't happen at idle or when I'm going faster, just when I'm going very slow. Usually happens when I'm pulling out of the driveway or something, happened once at a really slow turn at an autocross. I'm not sure where to look. Replaced the booster and MC (bench bled), bled everything a ton of times. So I'm thinking vacuum problem, but everything seems fine, car idles and drives properly, etc. I really want to get it fixed before I go HPDEing, anything iffy on the brakes is just bad.
Modified by turbohappy at 7:18 PM 8/23/2004
Old Aug 24, 2004 | 08:56 AM
turbohappy's Avatar
Default Re: No brake boost after putting around for a bit (turbohappy)
No ideas? Oh well, I was hoping that someone here would have more idea than the EF crew since racers care a lot more about their brakes.
Old Aug 24, 2004 | 09:03 AM
Drew M's Avatar
New User
If the pedal drops to the floor then it isn't the booster or vacuum supply. Either your MC is bad or you have a leak/air in the system.
Loss of the booster will make the pedal rock hard and increase effort - try pushing the pedal to the floor with the car not running. That is non-boosted braking.
Old Aug 24, 2004 | 09:08 AM
.RJ's Avatar
.RJ
Default Re: No brake boost after putting around for a bit (Evil Drew M)
Old Aug 24, 2004 | 09:11 AM
Drew M's Avatar
New User
Default Re: No brake boost after putting around for a bit (.RJ)
Yeah that is what I just said.
The pictures are helpful though.
Old Aug 24, 2004 | 09:20 AM
743power's Avatar
I have the same pedal falling to the floor problem, but it usually happens after the engine is under a load, or if I'm on the highway for awhile, and go to get off, I have no brakes.
New bb/mc are going in regardless of this problem, so I'm sure it will be fixed then.
Cute avatars guys.
Old Aug 24, 2004 | 12:48 PM
turbohappy's Avatar
Default Re: No brake boost after putting around for a bit (743power)
It's screwy. Every test in the Helms seems to pass, I'm not sure where to go looking. With a new booster and MC and lots of bleeding with no change at all, the only thing left I could think of is some sort of weird vacuum issue.
Old Aug 24, 2004 | 12:52 PM
Xian's Avatar
You've tested the vacuum check valve, correct?
Old Aug 26, 2004 | 12:11 PM
turbohappy's Avatar
Default Re: No brake boost after putting around for a bit (Xian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xian &raquo;</TD></TR><TR><TD CLASS="quote">You've tested the vacuum check valve, correct?</TD></TR></TABLE>
Yes, it has plenty of vacuum. Engine idles at about 2k RPM with that line pulled off.
Old Aug 26, 2004 | 02:00 PM
Shu's Avatar
Shu
If it passed all the tests in the Helms I'd check your wheel bearings. If the wheel woobles or deflects a lot when you pull out of your driveway it will push the calipers open and then you'll have long peddle travel when you first reapply.
Old Aug 27, 2004 | 07:34 AM
turbohappy's Avatar
Default Re: No brake boost after putting around for a bit (Shu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shu &raquo;</TD></TR><TR><TD CLASS="quote">If it passed all the tests in the Helms I'd check your wheel bearings. If the wheel woobles or deflects a lot when you pull out of your driveway it will push the calipers open and then you'll have long peddle travel when you first reapply.</TD></TR></TABLE>
Interesting thought. I'll check them. Would it follow that it would only do this at low RPM, not when I'm tearing around an autocross course or going down the highway?
Old Aug 27, 2004 | 11:11 AM
Jaker's Avatar
From thesounds of your description of the problem (pedal gets really hard) I'd call it a vacuum problem. Your booster is leaking out the vacuum, or its not building any to begin with. At part throttle cruise on the highway, or at idle you are likely getting alot stronger vacuum, but a low throttle, the booster doesn't see much vacuum coming from the motor.
Old Aug 28, 2004 | 08:41 AM
Shu's Avatar
Shu
Default Re: No brake boost after putting around for a bit (Jaker)
He said the pedal drops to the floor. That's not a vaccum problem. Does the pedal come back immediately with one or two pumps of the pedal and then it doesn't give you problems again until the next driveway encounter? If so I'm sticking to the wheel bearings. If the master was failing it would seem odd that it only occurs under certain conditions. Maybe your hitting the pedal harder or maybe softer under these conditions where your master may be failing under one or the other condition. Try sitting in you drive way for a while not rolling and push the pedal hard soft fast slow over and over again for as long as you can handle it. If it never gives you a problem then the master is ok.
Old Aug 30, 2004 | 08:23 AM
turbohappy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shu &raquo;</TD></TR><TR><TD CLASS="quote">He said the pedal drops to the floor. That's not a vaccum problem. Does the pedal come back immediately with one or two pumps of the pedal and then it doesn't give you problems again until the next driveway encounter? If so I'm sticking to the wheel bearings. If the master was failing it would seem odd that it only occurs under certain conditions. Maybe your hitting the pedal harder or maybe softer under these conditions where your master may be failing under one or the other condition. Try sitting in you drive way for a while not rolling and push the pedal hard soft fast slow over and over again for as long as you can handle it. If it never gives you a problem then the master is ok.</TD></TR></TABLE>
It drops close to the floor. The last 15% of the travel or something like that I have brake, but it's really hard. And it does come back after a couple pumps, no problems again until sometime later.
The MC is pretty new and it never gave me a problem doing your test.
I'll test the wheel bearings tonight, why would this not cause a problem while going faster?
crawlin
Nov 19, 2007 09:22 AM
sicrx69
Nov 15, 2007 02:19 PM
sasinorm01
Apr 11, 2007 07:56 AM
LSVTEC 91 Civic
Jul 6, 2005 07:59 PM
MooreBoost
May 25, 2004 04:50 PM
