Need help in replacing spark plugs...
Old Aug 23, 2004 | 09:14 AM
B18Redline's Avatar
Default Need help in replacing spark plugs...
I need to replace my spark plugs. Any info on which ones to buy and where?
I believe I need a 16mm socket and wrench to remove them. Is this right? Do I need to regap them or anything.....or just hand tighten them?
Thanks
Old Aug 23, 2004 | 09:17 AM
iixerOii's Avatar
Default Re: Need help in replacing spark plugs... (Redline07)
What year, model and make integra do you have? You'll also need the spark plug socket remover which is a long socket with a piece of rubber in it. NGK V power or up are always a good choice for spark plugs
Old Aug 23, 2004 | 09:21 AM
G-bonic's Avatar
Hijacked
Default Re: Need help in replacing spark plugs... (iixerOii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iixerOii &raquo;</TD></TR><TR><TD CLASS="quote">What year, model and make integra do you have? You'll also need the spark plug socket remover which is a long socket with a piece of rubber in it. NGK V power or up are always a good choice for spark plugs</TD></TR></TABLE>
I agree ... u dont need to regap them just check the gaps and wutever needs to regap do it....
Old Aug 23, 2004 | 01:22 PM
B18Redline's Avatar
Default Re: Need help in replacing spark plugs... (Stock_LS)
I have a 2000 gsr
Old Aug 23, 2004 | 01:32 PM
Octoman's Avatar
Use factory plugs if you are not modified. If you get them from the dealership the gap should be set, but it is always safe t check just to make sure. You can go to Sears hardware or autoparts store and pick up the correct socket for the plugs. Just use an extension to help reach in there. Remember! Don;t over tighten them or you will strip them.
Old Aug 23, 2004 | 02:55 PM
iixerOii's Avatar
Default Re: (Octoman)
Here's a list of the NGK available for you along with the stock number and parts number.
Product Name Stock Number Part Number
NGK IX iridium 3764 BKR6EIX-11
NGK Iridium plug 6741 IFR6E-11 0.052
NGK Double Platinum 4115 PFR6G-13
NGK GP platinum 7092 BKR6EGP 0.052
All the OEM gaps are 0.052
Old Aug 23, 2004 | 03:43 PM
Endless STi's Avatar
Default Re: (iixerOii)
ngk
Old Aug 23, 2004 | 03:44 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline07 &raquo;</TD></TR><TR><TD CLASS="quote">I need to replace my spark plugs. Any info on which ones to buy and where?
Thanks</TD></TR></TABLE>
dann that girl is cute...
*yes you would need an extension for spark replacement, torque wrench is the best tool but i used the regular one...just dont tight it too much or too hard...
go for NGK 9 man
Old Aug 23, 2004 | 05:08 PM
gsrboi80's Avatar
Default Re: Need help in replacing spark plugs... (yeegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 23, 2004 | 05:24 PM
CBRF4i's Avatar
If you dont have a spark plug socket that holds onto the spark plug just put your spark plug wire down there and grab onto it with that.
KloC 95 EG
28
Feb 2, 2009 12:35 AM
Dartanian
May 13, 2006 05:26 AM
jdmitr01
Oct 8, 2004 09:57 PM
Nocturnal
Mar 28, 2003 05:25 PM
Seedc2
Oct 25, 2001 06:59 PM
