Tranny know-hows needed
Old Aug 22, 2004 | 04:35 PM
wutupnut's Avatar
Default Tranny know-hows needed
A buddy of mine got a motor swap in the other day, and figured we'd drop a new clutch in it before sticking it into a car, needless to say we cannt get the tranny off. We got the bolts out, and the tranny will slide about 1/4 to a half an inch away from the block, but wont go any anymore, anyone know whats stopping it?
Old Aug 22, 2004 | 04:37 PM
allmotorteg_96's Avatar
Default Re: Tranny know-hows needed (wutupnut)
dumb ? but did you take out the starter
Old Aug 22, 2004 | 04:43 PM
wutupnut's Avatar
Default Re: Tranny know-hows needed (allmotorteg_96)
Yes, starter is taken out.
Old Aug 22, 2004 | 04:46 PM
you may just need to pull kinda hard on the tranny just dont let it sag on the input shaft
Old Aug 22, 2004 | 04:50 PM
wutupnut's Avatar
any certain way i should be tilted to miss the input shaft?
Old Aug 22, 2004 | 04:56 PM
s2kkid's Avatar
I did a Trans swap in my h22 lude once, And I swore to my self that i got all the bolts off...
It would come about 1/4 of the way off, then, it would spring back So I got to looking, and there was bolts on the back side facing the drivers side that i had no clue was up there.
The trans should slide off real easily.
you probally got them all out, But hey, I figured id share a similar story.
Old Aug 22, 2004 | 05:10 PM
wutupnut's Avatar
Default Re: (vtecluder97)
See what you did, after reading that i had to go back out there a look around One thing is, whoever he got the motor from they or someone else had managed to ship the two 17mm bolts on the back of the tranny that connect from the block to the tranny, looks kind like \__ brace. I head just went ahead and undid the 3 that was connected to the block to free it up, so could the 17mm be screwing anything up?
Old Aug 23, 2004 | 04:37 PM
Default Re: (wutupnut)
yes i would take that out
Old Aug 23, 2004 | 05:43 PM
wutupnut's Avatar
Default Re: (allmotorteg_96)
Finally managed to get them out, and waa laa the tranny broke loose. Thanks again guys.
pinecone
17
Jul 8, 2006 03:14 PM
Mistermark
May 1, 2006 02:45 PM
Ej1_coupe
May 17, 2005 08:37 PM
Unjockable
20
Nov 10, 2003 02:36 PM
VTC_CiViC
21
Sep 23, 2002 09:07 AM
