My Boosted GSR wont turn over this morning! Help! Only click on crank!
Old Aug 21, 2004 | 11:30 PM
AspectIndustries's Avatar
Default My Boosted GSR wont turn over this morning! Help! Only click on crank!
Kind of sucks, been few days since ive yet to figure out the problem. Worked the last night. I came home, parked car in garaged. And then next morning, all i hear is a click click... When i start the car. Everything powers up fine, hearing the fuel pump etc... Radio works.. Battery good...
This is what ive checked so far.
-All fuses under dash and hood OK.
-Starter is fine! Since ive tried to jump it directly from battery to the starter. Assuming the battery is fine also and the car only starts from there.
I tried driving around it for awhile, and no problem..
-Checked most of the connections, and seems to me everything is plugged in correctly... thats if im lookin at the right direction...
-All motor parts are still Grounded. Including battery.
I assume its the connection between the inside ignition to the starter..? Since the start will work direct jump from battery... Still hearing a click click! and nothting more....
Any idea, it might be my clutch not pushing the starter switch? Possibilities?
Please help!
Old Aug 22, 2004 | 04:52 AM
leed's Avatar
Default Re: My Boosted GSR wont turn over this morning! Help! Only click on crank! (synik)
If the 'click' you're hearing is coming from the starter try giving a couple of good hits w/ a hammer or something. Kinda like when your alternator starts to go **** up, a few good hits will net you a few more miles outa it.
Good luck
Old Aug 22, 2004 | 06:01 AM
Default Re: My Boosted GSR wont turn over this morning! Help! Only click on crank! (leed)
I can hear a click under the dash fuse box.. and another from under the hood fuse box..
Would it be possible to be my battery? Even Tho its possible to manually Jump start my car (using another wire from the battery to the Starter) I can jump start my car manually, and it runs... Just that it wont start inside.. So i assume the starter is still good. After manually running the car for 30 minutes, the battery shouldbe charged.... Yet, the motor wont crank still!
Any other suggestions? ( I will try to swap battery and see how it goes)
Old Aug 22, 2004 | 06:42 AM
tvrsir's Avatar
possible the igniton switch is bad. just the electronice side of it not thhe side where you stick the key in what year is your car? does it have immobilzer
try a new battery from a doner car first if i were you
Old Aug 22, 2004 | 06:46 AM
hypa's Avatar
man, that really sounds like a battery.
Like tvrsir said, try a new one before anything.
Old Aug 22, 2004 | 06:48 AM
Default Re: (hypa)
96 GSR Obd1
Yea, I will definately give that a try.. Ill let you guys know ina bit..
Old Aug 22, 2004 | 06:55 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">man, that really sounds like a battery. </TD></TR></TABLE>
I would prob put $$ that its the Batt or a bad ground. Try jumper cables, if they work then there ya go
Old Aug 22, 2004 | 07:02 AM
HXMan's Avatar
Its the battery.
Old Aug 22, 2004 | 07:08 AM
Default Re: My Boosted GSR wont turn over this morning! Help! Only click on crank! (HXMan)
The car will start, if i manually jump the starter, directly from the battery.. Will it be possible still..? ( its to early, I will try in a bit to change batteries)
Old Aug 22, 2004 | 07:24 AM
HXMan's Avatar
Hmmm....could be an ignition relay or something else in the ignition switch then.
Old Aug 22, 2004 | 07:35 AM
Syner-G-Racing LLC's Avatar
I just replaced my friends ignition in his steering column. it did the same thing.
1st try the battery swap, youll be suprised how stengy your car can be.
if that doesnt do it. go straight to the ingnition switch and check for 12 volts. if thats good.
check your ground wire, and the signal wire. if those are good.
check your ignition relay. if it doesnt click when you turn the key put a heat gun to it for a second and warm it up, still no click try shorting it out. no click check for voltage. no voltage. trace from there. if you got voltage though replace relay. there should be fuse also.
good luck
Hondacrf
Jun 16, 2017 04:13 AM
BistaYang
Jan 28, 2013 07:35 AM
JDMdb8isO
Feb 6, 2011 12:58 PM
xander1100
Oct 18, 2009 07:56 PM
tan2
Nov 4, 2002 10:10 AM
