weird problem on b18c1 ej
Old Aug 21, 2004 | 04:47 PM
nitelifegod's Avatar
Default weird problem on b18c1 ej
ok i was at the gas station and my car died, no fuel pump whine, no spark on distributor,
has new battery and new fuel pump( i connected the fuel pump direct and it turned on), do u guys think is the coil or ignitor?
thanks in advance for the answers.(car is a 1995 ej EX with B18C1)
Old Aug 21, 2004 | 04:51 PM
sohcvtec1995's Avatar
Default Re: weird problem on b18c1 ej (nitelifegod)
most likely the coil. get it tested.
Old Aug 21, 2004 | 06:01 PM
KiNG $h!t's Avatar
werd im having the same prob!!! where can you get teh coil tested?
Old Aug 22, 2004 | 06:37 AM
Default Re: (this guy 2fast)
but my fuel pump doesnt prime, and no spark everything thing else works
i think it migth be my MAIN RELAY
any ideas?
Old Aug 22, 2004 | 10:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast &raquo;</TD></TR><TR><TD CLASS="quote">werd im having the same prob!!! where can you get teh coil tested?</TD></TR></TABLE>
At like discount auto or auto zone, pep boys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitelifegod &raquo;</TD></TR><TR><TD CLASS="quote">but my fuel pump doesnt prime, and no spark everything thing else works
any ideas?</TD></TR></TABLE>
Did you check the fuses? cause i would think that you would blow a fuse befor the main relay would go.
Old Aug 22, 2004 | 01:35 PM
Default Re: (sohcvtec1995)
checked all fuses, cheched main relay
friend lend me a new 99 gsr dizzy,
still no spark
still fuel pump not priming,
car just cranks and cranks,
i'm taking to a mechanic tomorrow
Old Aug 22, 2004 | 02:30 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (nitelifegod)
sounds like a main relay.
Old Aug 22, 2004 | 05:16 PM
Default Re: (AzntaggeR)
already checked it, its good( checked with friends)
Old Aug 22, 2004 | 05:18 PM
slambedcivic's Avatar
no engine codes?
Old Aug 22, 2004 | 05:21 PM
mongoliandonuts's Avatar
Also, check the fuse box under the hood check ever freaking one i had the same problem i replaced the Coil, and ICM and it was just a damn fuse.
Old Aug 22, 2004 | 05:24 PM
nihonmufasa's Avatar
bad ignition switch can cause similar probs. You say main relay is good, did you check for proper voltage AT the relay with the ignition switch on?
Old Aug 23, 2004 | 04:23 AM
Default Re: weird problem on b18c1 ej (nihonmufasa)
i'm having a honda mechanic look at it today
lilsol89
Oct 22, 2008 06:06 PM
kaychi
Mar 28, 2007 03:56 PM
drumminforev
Jul 6, 2006 10:40 PM
Quad-Damage
Jan 2, 2006 12:39 PM
KamikazeRacinz
Mar 8, 2004 11:28 AM
