adjust boost on my deltagate?
Old Aug 21, 2004 | 04:32 PM
See Are X's Avatar
Default adjust boost on my deltagate?
i have a 4psi spring in my deltagate, can I turn up the boost without a MBC or without replacing the spring?
Old Aug 21, 2004 | 06:18 PM
b18b98's Avatar
Default Re: adjust boost on my deltagate? (See Are X)
the ghetto way is to put tiny pinholes in your vacuum lines which i don't suggest.
Old Aug 21, 2004 | 06:31 PM
D-Man's Avatar
only way to raise it otherwise is to screw the allen bolt on top of it in,you might get 7psi or so out of it.
Old Aug 21, 2004 | 07:10 PM
See Are X's Avatar
Default Re: adjust boost on my deltagate? (D-Man)
loosen or tighten it?
Old Aug 21, 2004 | 07:14 PM
D-Man's Avatar
tighten it,screw it in...raises boost
Old Aug 21, 2004 | 10:01 PM
turtle-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">tighten it,screw it in...raises boost</TD></TR></TABLE>
Be very careful when adjusting the screw in... If you adjust it too much, it will keep the wastegate from opening and BOOM!
Old Aug 21, 2004 | 10:40 PM
See Are X's Avatar
Default Re: adjust boost on my deltagate? (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">
Be very careful when adjusting the screw in... If you adjust it too much, it will keep the wastegate from opening and BOOM!</TD></TR></TABLE>
how will i know if I tightened it too much?
Old Aug 22, 2004 | 12:16 AM
Tchleung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">
how will i know if I tightened it too much?</TD></TR></TABLE>
Trial and error. tighten half a turn. then go for a drive. see where that put you to, and adjust from there
Old Aug 22, 2004 | 12:26 AM
honda9369's Avatar
Default Re: adjust boost on my deltagate? (Tchleung)
dude just get the boost controller. you can find one for a good price
Old Aug 22, 2004 | 07:47 AM
See Are X's Avatar
Default Re: adjust boost on my deltagate? (honda9369)
i've been looking for one around my area...for some reason no one has one...so I was just thinking about doing this for now
Old Aug 22, 2004 | 04:40 PM
Boostfed's Avatar
New User
Stop being cheap Nate! Ask mom and dad for money for a Boost controller!
Old Aug 22, 2004 | 05:22 PM
See Are X's Avatar
Default Re: adjust boost on my deltagate? (Boostfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">Stop being cheap Nate! Ask mom and dad for money for a Boost controller!</TD></TR></TABLE>
wtf are you talking about? this isnt nate, i pay for all my ****...thanks
Old Oct 1, 2004 | 11:51 AM
Symba2000's Avatar
Is that all you need to increase boost beyond 4psi? I'm currently using a T3/T4 Garrett Hybrid setup with a Deltagate that seems to limit me to 4psi.. I can't seem to boost above that even having adjusted my Pop-Off Valve and having screwed in the Deltagate in a bit.. Someone has recommended a manual boost controller, but I wasn't quite sure if that would fix the problem.. my goal is 6psi.. any suggestions?
Old Oct 1, 2004 | 05:17 PM
powerls's Avatar
ok seriously, you made the decision to Turbo your car. At least do it the right way. Ghetto turbos always end bad, spend a couple bucks, get a boost controller. odds are there are a couple for sale in classifieds.
Old Oct 1, 2004 | 08:10 PM
bern's Avatar
Default Re: (powerls)
A cheap alernative might be http://boostvalve.com/
I have mine turned almost all the way in, im getting 12 psi. Its cheap, and will do until I can afford else.HTH
Old Oct 1, 2004 | 09:34 PM
mpintegra96's Avatar
save up for a apexi AVCR i love it, it was worth every penny
ilikebigbutts
Dec 20, 2006 05:46 PM
turbodan4
Mar 7, 2006 09:09 PM
376R
Nov 13, 2005 05:49 PM
turbo95eg6
Jun 12, 2005 07:46 PM
WhiteSTi
Sep 26, 2003 10:30 AM
