power window problem (97 coupe)
Old Aug 21, 2004 | 03:52 PM
BigZ88's Avatar
Default power window problem (97 coupe)
ok guys, I have a problem that i just noticed recently. When i go to roll up my windows, I have a problem with the driverside window. It seems as though something is not as tight as it was before. The window seems to tilt towards the front of the car (like the front is not going up as fast as the back) so it goes up at a slight angle and gets caught on the window trim, and does not seal all the way around and leaves a slight gap in the front. I have to basically push the window back to get it to ride in the track correctly.
I know this is difficult to explain, but does anyone have any ideas on this? I will try to get pictures of the gap and the way it rides up funny..
Anyone have any ideas?
Old Aug 21, 2004 | 03:56 PM
JDM PRO's Avatar
Default Re: power window problem (BigZ88)
my 99 Si does the same and i am in the process of replacing my window regulator. Try to take out your door panels and see if the scissor part of the window regulator has some play in it.
Old Aug 21, 2004 | 04:19 PM
BigZ88's Avatar
Default Re: power window problem (JDM PRO)
ok, pending weather, i'll do that tomorrow.
Old Aug 21, 2004 | 10:25 PM
TurboCoop's Avatar
I have a 97 DX with manual windows and the drivers side came completely out of its track in the front of the door. When I go to put it up it gets stuck where the plastic from the side mirror meets at the front bottom corner of the window so it has like 4" its not going up. I have taken the door of and fixed it 5 times and it still does it.
hatchet_honda
Dec 21, 2010 04:37 AM
fongyz22
Honda Civic (2001 - 2005)
Oct 31, 2007 12:54 PM
PinoyxEJ6
Jun 8, 2007 11:22 AM
belz513
Jul 4, 2006 06:35 PM
acme
Nov 4, 2002 06:39 AM
