overreved problems " need help"
Old Aug 21, 2004 | 02:07 PM
93lsd's Avatar
Default overreved problems " need help"
i have a 98 coupe with a 2000 type r engine, was racing last night and went from 3 to 4 and instead went into 2 gear, drives alright but has a horrible idle, did a comp. test and had 170 in 1-3 and 205 in 4 with 20% leakdown in 1-3 and 10% in 4 my question is may be just some bent valves and need too replace the valve seals... any other suggestions
Old Aug 21, 2004 | 06:29 PM
evilone's Avatar
Default Re: overreved problems " need help" (93lsd)
could be bent valves, or your timing belt could have jumped a couple of teeth
Old Aug 21, 2004 | 07:34 PM
93lsd's Avatar
Default Re: overreved problems " need help" (prostockcrx)
i already checked the timming belt so i am guess it is the valves
Old Aug 21, 2004 | 10:23 PM
flow-zilla's Avatar
most likely the valve kisse dthe piston but sounds like you didnt really hurt to much you may just have to recon the head (valve job, grind the valves maybe replace valves,replace valve stem seals, and resurface deck).
Old Aug 22, 2004 | 07:07 AM
evilone's Avatar
Default Re: overreved problems " need help" (flow-zilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flow-zilla &raquo;</TD></TR><TR><TD CLASS="quote">most likely the valve kisse dthe piston but sounds like you didnt really hurt to much you may just have to recon the head (valve job, grind the valves maybe replace valves,replace valve stem seals, and resurface deck).
agree
Old Aug 22, 2004 | 07:29 AM
JDM2ndGen's Avatar
yea this same thing happened to my friends ITR at the track ...barely made it home before it crapped out on him ...
Old Aug 22, 2004 | 09:46 AM
93lsd's Avatar
Default Re: overreved problems " need help" (JDM2ndGen)
thanks for the input, but the car runs fine just has a jacked up idle, thinks its time for a built up
Old Aug 22, 2004 | 09:48 AM
93lsd's Avatar
would that also explain the low comp in each cyl...
Old Aug 22, 2004 | 03:58 PM
evilone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd &raquo;</TD></TR><TR><TD CLASS="quote"> just has a jacked up idle </TD></TR></TABLE>
leaky intake valves???????
raverx3m
May 18, 2011 11:24 PM
Baron55
Aug 9, 2005 03:27 PM
smokey2.0
Dec 27, 2003 05:18 AM
Rob Dizzle
21
Jul 3, 2003 12:33 AM
JeffNA
May 20, 2002 06:59 AM
