Low Idle Guru's please chip in !! ----- 94 GSR 200rpm idle? so low it will bog
I bought a turbo'd GSR about 4 months ago. After wrestling with the turbo back and forth i decided to sell the turbo kit and just go N/A. I sold all my turbo pieces and bought Aftermarket N/A parts.
I replaced the injectors with the H series injectors, and replaced all the vacuum lines. I got every thing in, but i am having a low idle problem when the car is in neatrual or when i am going to a stop, it would get so low that it would shut off.
The car idles about 200 rpm before shutting off which is WAY too low.
My friend and i checked the MAF, and checked the timing. They were both good. The car isn't throwing any codes either.
So bascially my question is what would cause low idle ? The one's i can think of is currently
1. Vacuum leak
2. Injectors are bad ?
3. IACV <--- but if this is bad wouldn't the ecu throw a code ?
So i am thinking about re-looking through my vacuum, and giving it a minor tune up.
Any one else had this problem of VERY LOW IDLE ( so low that it would just bog, and shut off in every stop, and neatrual position of gear ).
Well thanks in advance,
-Jee
1. Vacuum leak
-Jee
Ek4 SiR
Nov 27, 2010 01:58 AM
TurboSI24
Nov 23, 2005 03:39 PM
