obd0 engine with obd1 IM, what ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 »</TD></TR><TR><TD CLASS="quote">92 hatch, with a (88-91) d16a6 motor, but with the 92 cx obd1 intake mainfold, which ecu would he want
-PM6
OR
-P28.......?
what distributor is he using? if its the a6, than obd0 ecu(i dont know if they make an obd1 to obd0 jumper harness though) if he is using an obd1 dizzy, than he has to use an obd1 ecu.
theres more to it than this though, you also have to have the right o2 sensor depending on what ecu you are using. hope this helps a little.
-PM6
OR
-P28.......?
