mid shifted and over reved
Old Aug 21, 2004 | 09:18 AM
jianwa's Avatar
Default mid shifted and over reved
didnt see where i over reved too, heard clickiing noises after stopping, and the bolts on my cam gears were lose, 2 were missing, need help please
Old Aug 21, 2004 | 09:25 AM
slambedcivic's Avatar
Default Re: mid shifted and over reved (jianwa)
adjust your valves?
im not really sure what you did or what youre asking because of how you worded it.
Redline96LX's Avatar
* B A N N E D *
****, coulda bent a valve or two. Gonna have to replace those missing bolts. Check your cam, may have to replace that too. Check its runouts and replace all the bolts on your valvetrain to be safe. I'd check all the binders for the cam. Check the valves too.
Old Aug 21, 2004 | 09:28 AM
jianwa's Avatar
Default Re: mid shifted and over reved (Redline96LX)
damn low on cash, dont think i can replace my cams right about now, is there any other issues i should be lookin at and how much would all of this be, fixing it myself is out of the question, rough idle, kinda hard start,
Old Aug 21, 2004 | 09:29 AM
if youre horrible on cars. and you know you are. then i suggest you take it to a mechanic.
Old Aug 21, 2004 | 09:39 AM
* B A N N E D *
Trust me, this will not be cheap.
Old Aug 21, 2004 | 09:46 AM
shiftgear8000's Avatar
who knows....if the cam gear bolts came off, the gears could of slipped.....could of jumped a tooth. But since it has a rought idle and it's hard to start.....I'm pretty sure it's a timing issue.....hopefully you didn't bend any vavles in the process. Anyways, probably won't be cheap to fix.....good luck
Old Aug 21, 2004 | 10:32 AM
jianwa's Avatar
Default Re: (shiftgear8000)
what would be considered not cheap to you heh guess i should go round up as much as i can right now
Old Aug 21, 2004 | 10:45 AM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jianwa &raquo;</TD></TR><TR><TD CLASS="quote">didnt see where i over reved too, heard clickiing noises after stopping, and the bolts on my cam gears were lose, 2 were missing, need help please</TD></TR></TABLE>
my advice, don't race a bruised engine when you have no money....because that's when you WILL break something.
case in point = you
Old Aug 21, 2004 | 12:44 PM
jianwa's Avatar
Default Re: mid shifted and over reved (stackz)
well the over rev cause all that.. so i wasnt racing it when it was bruised
Keenor
Jan 24, 2011 12:48 PM
JDM_EK4_Coupe
Apr 30, 2007 12:19 PM
Chuji
Jul 6, 2003 06:16 PM
90teg
Jun 27, 2003 06:48 AM
Ovl55rag
Dec 12, 2002 09:44 PM
