DSM injectors on my d16y8
Old Aug 21, 2004 | 07:51 AM
shiftgear8000's Avatar
Default DSM injectors on my d16y8
My friend gave me a set of DSM injectors.....wanting to use them for my turbo set up. I was just wonder if they will plug right in....or if I had to do any modifications to get them to work?
-jase
Old Aug 21, 2004 | 08:01 AM
monicle's Avatar
Default Re: DSM injectors on my d16y8 (shiftgear8000)
you need to wire up an injector resistor box. there are pleanty of walkthroughs on HT about this or you can check out my install here. http://repo.jackmoves.com/album153
there are more in depth instructions if you search.
Old Aug 21, 2004 | 08:11 AM
awesome, thanks Now I just gotta find a resistor box.......
you think it's worth the trouble, or should I just go buy some new injectors?
Old Aug 22, 2004 | 03:20 AM
jdmh22eg's Avatar
heard of it working...n e pics...
Old Aug 22, 2004 | 05:05 AM
Bambooseven's Avatar
you don't need a resistor box. go to radio shack and buy 4 10ohm 10 watt resistors and wire them inline on the wires to your injectors. You might have to bore the injector seals a little bit, other then that it is pretty straightforward.
Old Aug 22, 2004 | 08:13 AM
blackeg's Avatar
Default Re: (Bambooseven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bambooseven &raquo;</TD></TR><TR><TD CLASS="quote">you don't need a resistor box. go to radio shack and buy 4 10ohm 10 watt resistors and wire them inline on the wires to your injectors. You might have to bore the injector seals a little bit, other then that it is pretty straightforward.</TD></TR></TABLE>
most definately. wiring the inline resitors was much much cheaper and easierr then a resistor box, as i did it to my 93 ex a few months ago. the inside of the injector seal that sits in the manifold needs to be bored out pretty good, but a dremel will do it nicely. also if you want to use the stock civic injector clips, take a knife and cut out the little **** thats inside the injector clip, cause it wont slide onto and lock in place on the dsm injector with this piece still in the clip. oh yea, wire them into the power wires, not into the grounds(the injectors pulse via grounds from the ecu and the power is a constant supply) i know for my civic the power wires were yellow with a black line. check the helms to double check for your car
2ndchirp
Oct 26, 2008 05:09 PM
mortificationrock
Jun 10, 2007 09:05 PM
yodas-gsr
Oct 24, 2005 01:41 AM
99TurboFerio
13
Mar 7, 2005 02:27 PM
Boosted LS
Jul 9, 2003 08:52 AM
