ECU upgrades
so far i got AEM cai and my catback exhaust is on the way, installed next weekend hopefully. also will be doing a header and either test pipe or hi flow cat. pulleys, cams eventually
a VAFC will you do you fine if you are planning such a mild build.
if you consider running higher compression for NA or boost then an ECU upgrade would be more of an importance to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeSHhhh »</TD></TR><TR><TD CLASS="quote">im new to the honda scene... what is EFI PMS?</TD></TR></TABLE>
it's a piggyback system, a little more capability than a VAFC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveO000000001 »</TD></TR><TR><TD CLASS="quote">what is VAFC</TD></TR></TABLE>
4 words. IBTL.
4 words. IBTL.
lol, this thread is funny.
If you do an ECU upgrade you are mostly likely going to lose the ATTS unless you just use a VAFC. No need for any engine management until you move to the head/block. Maybe an FPR to rich it out if you get an insane header.
