Oil Leaking From B16 Gaskets....Please Help... And where can i find a Johnny Racecar Intercooler?
I have a b16 and it looks like me head gasket is blown but there is no smoke coming out of my exhaust.. and if i look ontop the head i see that the corners on the vaLVE COVER HAVE OIL ON IT(NOT ALOT BUT YOU CAN SEE OIL) and there is a dip between the head and the dizzy what you can see some oil too.. i cant figure out what its coming from....has anyone heard if this is common on b16's or what... i bought a new valve gasket but i cant find a o-ring for th dizzy...does anyone have any suggestion.... thank
sounded like your leak could come from 2 places. behind the dist. there is an o-ring it could have leak from there, the other is you cam seal. go to advance auto and the a complete kit make by fel pro. it would have all the (8) groumets, (4)dizzy tube seals, and valve cover gasket for $16.00 plus tax. just order 2 more from them
Guest
Posts: n/a
How bout trying out http://www.johnnyracecar.com I heard they might have some.
thanks for the help. they look really nice but the only ic piping i can find is $300. do you have any secrets or sources for ic piping?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh »</TD></TR><TR><TD CLASS="quote">would you put LOWES black couplers or should it be welded together..</TD></TR></TABLE>
They'll blow up like a baloon and pop.
Guest
Posts: n/a
Go to someplace like Napa and ask reinforced hose to what diameter you need. only thing is that if you don't have a bead where you connecting two pipes more likely there just gonna blow off from the boost. Just buy some jb weld and make some beads around the ends of your charge pipes and be done with it.
Scott4uf21
Sep 2, 2009 02:58 PM
90CivicDaily
12
May 4, 2008 10:12 AM
