anyone with a d15z1
Old Aug 20, 2004 | 09:04 PM
em Dot's Avatar
POOPCheeks
Default anyone with a d15z1
does anyone know where i can get a d15z1 and is it swap worthy?
Old Aug 20, 2004 | 09:41 PM
Change's Avatar
Default Re: anyone with a d15z1 (em Dot)
why do you want to swap that?
Old Aug 20, 2004 | 09:44 PM
Change's Avatar
Default Re: anyone with a d15z1 (pSI civic)
D15Z1 1493cc 92hp@5500 97ft-lbs@4500 9.3:1 comp ratio 75mm bore 84.5 stroke sohc obd1 from 1992-1995 Civic VX
Old Aug 20, 2004 | 09:56 PM
Change's Avatar
http://www.partsadventure.com/
http://www.importautosalvage.com/
Old Aug 21, 2004 | 11:03 PM
em Dot's Avatar
POOPCheeks
what single cam motor should i get since im on a low budget?
Old Aug 21, 2004 | 11:05 PM
em Dot's Avatar
POOPCheeks
so basically a z1 is the stock crx motor but with vtec? would the d15b vtec from hmotors a good buy? i'm not sure what to do to my crx since i'm still a student and only work part time
Old Aug 21, 2004 | 11:33 PM
Squallie's Avatar
mini me swap i forgot what the thread was but if someone could post it up that would be cool...
Old Aug 22, 2004 | 12:02 AM
em Dot's Avatar
POOPCheeks
Default Re: anyone with a d15z1 (Squallie)
is a mini me swap the same concept as the ls vtec? b/c thats what me and my friend are gonna do. what kind of power can i get out of the mini me?
Old Aug 22, 2004 | 08:09 AM
em Dot's Avatar
POOPCheeks
i found a d15b vtec im gonna pick up in a week or so. its going to be my first swap im doing so does anyone have any advice?
Old Aug 22, 2004 | 08:43 AM
EJ2-Fluffy's Avatar
I would've went with the D16z6. A lil more displacement and crapload of aftermarket parts available in the US compared to the d15b. Have fun man, good luck on your project.
-Jon
Old Aug 22, 2004 | 04:42 PM
em Dot's Avatar
POOPCheeks
Default Re: (CRX-Fluffy)
thanks hopefully everything will bolt up and wont be too much of a problem.
K20ACRX
18
Mar 12, 2010 12:41 PM
Pontas
Sep 7, 2008 12:49 PM
DC5_Monkey
Jun 23, 2008 11:30 AM
Suzukablue
37
May 6, 2003 07:20 AM
