Mini Me Swap or complete SOHC v-tec swap?
KEEP THE NEGATIVE STUFF OUT
just trying to get some positive input
okay i have a 92 ferio with a stock lx motor in in, the mielage is 218,xxx right now but runs healthy because the previous owners took good care of the car.
what im looking to do is a swap but nothing flashy just a lil more power than i got right now, ive had cars with v-tec and i would like this car to have that lil kick to it.
Could i do a mini me swap and switch out heads and replace ecu and wire up for v-tec or should i just do a full swap?
also if anyone knows how much roughly around the price range of the mini me or complete swap would be just post it up plz
Re: Mini Me Swap or complete SOHC v-tec swap? (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">you can get a single cam vtec for a couple hundred bucks...you'll see more power with the whole swap than the mini me</TD></TR></TABLE>
is the couple hundred bucks just for the motor only? any recommendations on a motor also? i was thinking about the d16y8 but then i would need to change out the ecu, wires for v-tec and iono if i could use the stock tranny i got.
Re: Mini Me Swap or complete SOHC v-tec swap? (DC5_Monkey)
i think its like 800 for a y8 with trans and ecu...i not 100 percent on that cause i never bought one but its gotta be in that area...you dont want to go b series?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">i think its like 800 for a y8 with trans and ecu...i not 100 percent on that cause i never bought one but its gotta be in that area...you dont want to go b series?</TD></TR></TABLE>
well i was thinking about going b series but its more expensive and i figured that the SOHC v-tec would be cheaper.
but if i can get a good price on a b16 that would be okay
bought my y8 motor for 100$
bought my y7 motor for 150$
p28 obd1 ecu 110$
rywire vtec harness. Like 40$
rywire obd2-obd1 dist harness40$
reuse transmission. it bolts right up free.
y7/y8 mini me runnin low 15's for under 500$. thats pretty cheap.
thats what my friend spent on his setup. i have the same setup but my y8 got a full valve job, 230$ at sfl machine and crank in greenacres.
and the block i replaced all the bearings, rings, water pump timing belt oil pump pickup tube and head gasket set. dont remember what i paid for all that but it was prob 300-400$ my price at honda.
p28 obd1 ecu 110$
osc007
04-09-2012 07:59 AM
