Clutch problem in Del Sol
Old Aug 20, 2004 | 06:45 PM
Apocolipse269's Avatar
Default Clutch problem in Del Sol
Hey, i just rebuilt my Engine and now my clutch is having a slight problem.
First, i spent like an hour draining the brake fluid and adding new brake fluid from the clutch system and pumping it up to build up the pressure needed, but it seems like my clutch is soggy. When it comes back, the hydraulic part stops b4 it gets all the way out, and then the spring part pulls it the rest of the way out. Is there any ideas on what's happening and what i can do to remedy? thanx
Old Aug 20, 2004 | 06:47 PM
Sliced Beard's Avatar
Default Re: Clutch problem in Del Sol (Apocolipse269)
keep bleeding the clutch for another hour of so and it will get stiff
Old Aug 20, 2004 | 07:09 PM
hayabusa160's Avatar
Default Re: Clutch problem in Del Sol (dirtyd463)
what i did was connect a tube to the bleeder screw and let the fluid dribble down to it and keep adding fluid. i let it dribble for like 5mins. close the bleeder screw pump it a few times and did it again worked pretty good.
Old Aug 20, 2004 | 08:40 PM
SiRII_Izzy's Avatar
Make sure you check the slave cylender maybe there is something wrong with that check for leaks... Um it also maybe damage from the inside like the seals good luck
94SolMan
Apr 29, 2009 12:07 PM
BedDeMoN
Apr 1, 2009 03:42 PM
shadhman
15
May 11, 2008 07:51 PM
civicb16eg
May 7, 2007 03:47 PM
halfNhalf-83
Sep 14, 2004 06:00 PM
