transmission or clutch?
transmission or clutch? Another Problem *Edit*
i have a problem that im trying to figure out before either order a new clutch or buy another transmission..the car will go into gear when the car is not on but when the car is on the gears wont go in...so my problem is could this be the transmission or the clutch? btw its a obd1 gsr into an eg
Modified by civicb16eg at 5:18 PM 4/27/2007
ez first of before you change the clutch or nething check your fluids if there low add fluid leave cap off go into the car pump the clutch petal constantly for about 3 mins this will bleed it then add more fluid do the same thing pump for 3 mins add more if needed then check it every time you get gas just to see if its low again btw if you didnt know BRAKE FLUID goes into it not POWER STEERING FLUID if thats not the case then clutch
Re: (civicb16eg)
well i have another problem...so i put a new clutch in but i forgot to resruface the flywheel...can this be the reason why the car would stall?... it occasionally stalls when im on a hill and when the car is about to stall the clutch pedal wont kick back up.. is it because i didnt bleed the cluctch line right?..please any suggestions would be great
1 Post
Re: (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">yes you need to re-bleed the clutch again. If the pedal lays on the floor and doesn't kick back up, it still has air in the line.</TD></TR></TABLE>
or ur pressure plate is bad, which i so unfortunetly just found out...
hondapwr
19
12-21-2007 06:16 PM
iixerOii
10-13-2004 01:48 PM
Qwikrex
04-20-2003 03:27 PM
