RACING CHIPS FOR ACCORDS
I am very interest in getting a MUGEN racing chip for my car. My friends have told they do not work, but I was wondering if anybody has had one put in their accord and can tell the diffrence with it in
waste of money on a stock or bolt on car. what you need is the exact same engine that hte chip was made for. then it will help compared to a stock ecu...
also when did mugen ever make a part for a sohc accord engine??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">waste of money on a stock or bolt on car. what you need is the exact same engine that hte chip was made for. then it will help compared to a stock ecu...
also when did mugen ever make a part for a sohc accord engine??</TD></TR></TABLE>
Well they must have made one because its on ebay everywhere. And if its on ebay it must be for real. Nobody evAr sells fakes on ebay
chiping a 4cyl honda
chiping a cummins turbo diseal chevy truck
just because someone off the coast of madagascar glues an emblem onto a piece of plastic doesnt make it mugen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">chiping a 4cyl honda
there's nothing wrong with the chipping method of tuning, as long as the chip is custom made and custom tuned to the exact car/engine and ecu...for instance, i am currently using a p28 which i spent time tuning on a dyno to get a custom ROM made for my exact modifications...we were able to make about 11 more hp and 7 lb/ft tourque just from that dyno session...
but as to the original question, buying a cheap chip off ebay isn't going to do you any good...in fact it will most likely hurt you...most of those remove the rev limit and freely enable you to rev your car however high you want...it's a common fact that the f22 doesn't even make power in the higher rpm's...also, hope you never accidentally downshift to the wrong gear on the fly and over rev your motor w/o a rev limit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94AccordPimper »</TD></TR><TR><TD CLASS="quote">Ok guys thanks for the feedback. I will look into a more quality chip before installing it! Thanks for the advice
nick makes an excellent point about the custom work......the one thing to remember is that an ecu change is a finishing touch......theres really not much good in changing the ecu when all you have is a SOHC f sereies motor with a APC intake and a bomz muffler w/ led light up tip
</TD></TR></TABLE>nick makes an excellent point about the custom work......the one thing to remember is that an ecu change is a finishing touch......theres really not much good in changing the ecu when all you have is a SOHC f sereies motor with a APC intake and a bomz muffler w/ led light up tip
TroyboyEK
Sep 6, 2008 10:34 PM
ThaCivicAssassin
Jul 8, 2004 04:56 PM
RotaryBzzz
Jan 27, 2003 09:35 PM
kay_animation
Dec 8, 2002 05:43 PM
