Clutch Chatter Vibrations?
Old Aug 20, 2004 | 10:34 AM
Rocks
Guest
Posts: n/a
Default Clutch Chatter Vibrations?
I get a real bad shaking and vibration feeling when I take off from a start in my car. The car shakes and you could hear this chattering (im almost sure its from the clutch) and then after you get to a certain speed about 75MPH it stops. Any ideas what could this be?
Old Aug 20, 2004 | 10:45 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Clutch Chatter Vibrations? (Rocks)
Is it only during engagement when your slipping your clutch a little to get moving? What happens when you're moving and you press the clutch pedal in, does it stop? need some more info..
Old Aug 20, 2004 | 10:46 AM
Deemeetree's Avatar
Electrician
Glazed flywheel?
Old Aug 20, 2004 | 10:48 AM
Rocks
Guest
Posts: n/a
Default Re: Clutch Chatter Vibrations? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Is it only during engagement when your slipping your clutch a little to get moving? What happens when you're moving and you press the clutch pedal in, does it stop? need some more info..</TD></TR></TABLE>
When Im on the throttle the car moves when I put it in neutral the car gets no vibration and no shaking. I thought it was my mounts but I guess not.
Old Aug 20, 2004 | 10:55 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks &raquo;</TD></TR><TR><TD CLASS="quote">
When Im on the throttle the car moves when I put it in neutral the car gets no vibration and no shaking. I thought it was my mounts but I guess not.</TD></TR></TABLE>
Ok so are you saying that when you're on the gas and accelerating, you get a bunch of vibration? but when you put the car in neutral and coast it doesn't? what about when you gear down, what happens then?
Old Aug 20, 2004 | 10:58 AM
Rocks
Guest
Posts: n/a
Ok so are you saying that when you're on the gas and accelerating, you get a bunch of vibration? but when you put the car in neutral and coast it doesn't? </TD></TR></TABLE>
yes exactly when i gear down ???Hmmmm I dont know I havent paid attention to that
Old Aug 20, 2004 | 11:48 AM
Rocks
Guest
Posts: n/a
Old Aug 20, 2004 | 01:38 PM
Rocks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks &raquo;</TD></TR><TR><TD CLASS="quote">I get a real bad shaking and vibration feeling when I take off from a start in my car. The car shakes and you could hear this chattering (im almost sure its from the clutch) and then after you get to a certain speed about 75MPH it stops. Any ideas what could this be?</TD></TR></TABLE>
Old Aug 21, 2004 | 10:30 AM
00Red_SiR's Avatar
All Motor Mentor
Sorry about getting back to you...being new, I can only post 5 times in one day and I reached my limit when I was talking to you yesterday.
Clutch chatter happens when you are taking off from a dead stop and are slipping the clutch to get you going. This mainly happens if your flywheel is glazed from slipping the clutch a lot or if you change the clutch without resurfacing the flywheel. When you're doing this, if you get a lot of vibration back through the clutch pedal and some "chattering" noise that's clutch chatter. It sounds to me like it's more drive line related in your case...maybe a bad cv joint/axle or engine/tranny mount....hard to tell without more information.
globy123
Nov 29, 2007 11:21 AM
zach1288
16
May 9, 2007 05:57 AM
SoullessJapaneseMachine
15
Feb 22, 2007 10:16 PM
turnsignalandy
14
Aug 22, 2006 07:13 AM
AspectIndustries
Jan 5, 2004 07:49 AM
