B20Z Leaking Coolant
Hey I got a b20Z swap in my 2nd gen teg and it is leaking coolant. Any ideas what it could be we have changed the water pump gasket twice and its still leaking any other ideas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexTypeS »</TD></TR><TR><TD CLASS="quote">Hey I got a b20Z swap in my 2nd gen teg and it is leaking coolant. Any ideas what it could be we have changed the water pump gasket twice and its still leaking any other ideas</TD></TR></TABLE>
If coolant is still leaking out at the water pump it is probably 1 of 2 things. The weep hole seals are bad and allowing excess fluid to drain out there or it could be a bad water pump main bearing seal allowing fluid to leak out from behind the pulley on the water pump. Either way I would just change out the pump clean up the area real nice and use the black gasket maker silicone stuff on the new water pump gasket to make a good seal.
RenoRacing
Oct 28, 2002 04:52 AM
