throwing code 43 Fuel supply system
Old Aug 19, 2004 | 10:09 PM
craiger's Avatar
Default throwing code 43 Fuel supply system
what is the problem the fuel pump or ????????
and sometime i get good old code #7 tps sometimes and then sometimes i get code #4 iacv
i own a 99 civic hatch with a jdm b18c p72 motor with a obd2 to obd1 on it and then i have p61 ecu with a tuned hondata s200 on it
help me please
Old Aug 19, 2004 | 11:49 PM
CarsCarsCars's Avatar
Default Re: throwing code 43 Fuel supply system (craiger)
I guess the first thing i would check is the fuel filter. When was the last time it was replaced?
Also testing the fuel pump to see if its good or not is not a very hard thing to do, so you could look into that if you think its bad. If the pump seems ok id definitely guess the fuel filter then.
Old Aug 20, 2004 | 11:47 AM
craiger's Avatar
Default Re: throwing code 43 Fuel supply system (CarsCarsCars)
yeah i was planning on changing it so ill do that and then i check the pump as well thanks
H-Civ-Hatch-04
Honda Civic (2001 - 2005)
Mar 30, 2015 02:20 PM
CorrodeONE
Feb 2, 2009 10:02 PM
Asahi
Nov 17, 2003 07:30 AM
92-h23a1
May 14, 2003 11:25 PM
riceboy
Dec 11, 2002 12:04 PM
