any knowledgable peeps with a Vortech 99-00 Si
Old Aug 19, 2004 | 08:59 PM
SiShane's Avatar
Default any knowledgable peeps with a Vortech 99-00 Si
Im kinda considering it for my FBP. I bought Skunk2 stg 2s but Im thinking of selling for a Vortech. Any bitches grips or complaints. Any good setups you guys recommend? I should have about 4gs to play with after I sell my other car and sell the cams. I was thinking about rims but IM like naaa. Speed would be better.
Old Aug 19, 2004 | 09:27 PM
hadboosttroy's Avatar
Default Re: any knowledgable peeps with a Vortech 99-00 Si (CRexer101)
It will be pretty fast for a fun street car, but the powerband sucks ***.
Old Aug 19, 2004 | 09:34 PM
quik sol's Avatar
I have a friend with a vortech kit on his 99 si he ran a 14.5 stock exhaust/stock everything just the kit, its a nice kit for the people who don't want to try and break some records.
Old Aug 19, 2004 | 09:35 PM
Boostfed's Avatar
New User
ClubSiRacer or Jason SiRacer on ClubSi has one, has aloyt of money into it and is decent. Check him out on here or ClubSi
Old Aug 19, 2004 | 09:38 PM
braintree's Avatar
Good kit fresh out the box. Anything after the 12-15 psi mark will require dealing with belt slipping. Paynetech makes an 8rib set up thats nice but pricey. I use to have it on my em1. My only complaint was the lowend power. Other than that, the fitment was good and no real mechanical problems.
Old Aug 20, 2004 | 01:52 AM
SiShane's Avatar
Default Re: any knowledgable peeps with a Vortech 99-00 Si (braintree)
so the powerband is shitty...how. is there like no low end?
Old Aug 20, 2004 | 05:08 AM
PH_B16-VTi's Avatar
The kit "out of the box" runs like 9psi and the compressor is HUGE, so it's like strapping a giant turbo on a car and it never spools up. So the low end suffers from this as the vortech must be in high revs to be in the "friendly zone". But if you like messing around with it abit like SiRacer you can install a CRV pully and you'll get about 11psi at 8000rpm and much more bottom end than with 9psi on top.
Dyno:
http://www.clubsi.com/dyno_vortech_1.shtml
http://www.clubsi.com/dyno_vortech_2.shtml
As you see psi will follow rpm so more power on top, better bottom.
Hope this helps...
/PH
el arbi
Aug 2, 2003 02:11 PM
B18C-EJ1
Oct 17, 2001 07:30 AM
Reverend
Sep 12, 2001 11:09 AM
