1994 D15B7 DX engine into 89 CRX ...questions!
Old Aug 19, 2004 | 01:45 PM
0ptimus prime's Avatar
Default 1994 D15B7 DX engine into 89 CRX ...questions!
Alright guys, this is my first time swapping an obd1 engine into an obd0 car. I have some questions...
First off, we've already purchased the obd0-1 conversion harness so that we can use the P06 (obd1 DX) ecu. OK my question is......What harness do i use on the actual engine?
Do i use the CRX HF harness (obd0) on the OBD1 engine? Or do i use the DX engine harness (obd1).
If i use the DX harness, how do i get it to fit at the shock tower? I know the connections are different.
If i use the HF harness, do all of the sensors and plugs go in the same on the OBD1 engine?
Also, for the ECU pigtail, do i wire the bare wires to the firewall side of the shock tower connections?
Thanx for some input.
Old Aug 19, 2004 | 02:59 PM
Default Re: 1994 D15B7 DX engine into 89 CRX ...questions! (0ptimus Prime)
COMMON you bastages !
AllmotorGSReg
Sep 23, 2008 11:40 AM
nitroracer
Sep 9, 2006 07:50 PM
E_F_9
Dec 25, 2005 07:36 PM
0ptimus prime
Aug 22, 2004 06:52 PM
0ptimus prime
Aug 20, 2004 09:14 AM
