What is LS/VTEC? noob here
Old Aug 19, 2004 | 01:33 PM
shinji666's Avatar
Default What is LS/VTEC? noob here
I'm new to this forum and i searched around but i still don't get it after reading them. When ppl ay LS/VTEC, does that mean they convert the engine in LS to vtec? and how much that conversion usually cost? and Would it be the same as GSR (170bhp) ?
Old Aug 19, 2004 | 01:40 PM
Marauder's Avatar
Default Re: What is LS/VTEC? noob here (shinji666)
You put a GSR head on a LS motor and convert the electronics to run VTEC.
Old Aug 19, 2004 | 01:55 PM
old_school_dohcvtec's Avatar
yea its when you put a GSR head on the LS block. But since the redline for the block is 6.9 and the head is 8.0 you cant rev it all the way.
The plus is that there is more torque but i ono about doing such a conversion
Old Aug 19, 2004 | 02:01 PM
G-bonic's Avatar
Hijacked
The lsvtec is the combination of non vtec block and a vtec head....
Old Aug 19, 2004 | 02:07 PM
sabotage7's Avatar
heres my friends if that helps you any! http://www.cardomain.com/id/bigbodysmith
Old Aug 19, 2004 | 02:44 PM
batmang yO!
Guest
Posts: n/a
I know what ls/vtec is but im no expert on it, but i'll tell you this, its not as simple as just bolting on a b18c1/c5 or b16 head on an ls block. If you don't even know what ls/vtec is then I HIGHLY recomend you use the search feature here on ht as well as other honda related forums, and research, research, research, you can never research enough.
BTW, you do know what a "head" is and what the "block" is right? and possibly what they do?
Old Aug 19, 2004 | 02:56 PM
aziz93's Avatar
Default Re: What is LS/VTEC? noob here (Beavis)
It is as simple as bolting a vtec head on the ls block. They got kits for it so no drilling is required . and if you want to rev up to vtec limits just change your rod and head bolts to arp units, and change your oil and water pump to b18c ones. Get a fuel pressure riser (regulator) vtec ecu. Then ride away with 35cc and way more torque than any other b18(unstroked or bored).
B16b or type r heads are the heads to have. and the average is about $1400 with evrything i mentioned above. That is if you get a 100%complete head for cheap 5-6 hundo
Old Aug 19, 2004 | 11:10 PM
shinji666's Avatar
Default Re: What is LS/VTEC? noob here (aziz93)
if i have LS auto, and converted to vtec.. would i get 170hp? or it doesn't benefit me because auto don't take advantages of high revs
Old Aug 20, 2004 | 12:22 AM
LSvtec03's Avatar
https://honda-tech.com/zerothread?id=501372
chargedek
Dec 22, 2005 04:27 PM
NCwhite93integra
Jun 3, 2005 12:47 PM
helpmeplease
Oct 29, 2004 11:31 PM
IntegRACER
Jan 15, 2003 02:30 PM
integra81
Nov 22, 2001 04:11 PM
