Can brand new OEM parts go bad?
Old Aug 19, 2004 | 10:51 AM
B2FiNiTY's Avatar
Default Can brand new OEM parts go bad?
I just had an oem water pump professionally installed less than 3000 miles ago and I think it is leaking again. Is it possible that this water pump was bad?
Old Aug 19, 2004 | 10:57 AM
93 VTEC's Avatar
Default Re: Can brand new OEM parts go bad? (B2FiNiTY)
thats IMPOSSIBLE...lol j/k man. I have never seen one go bad with such low mileage. Most likely it's the coolant pipe o-ring where it meets the water pump or the gasket where the water pump meets the block. Just because you had a 'professional' install it doesn't mean it was done right. They make mistakes too.
Old Aug 19, 2004 | 11:00 AM
B2FiNiTY's Avatar
Default Re: Can brand new OEM parts go bad? (93 VTEC)
So what would you suggest I do to fix this problem? Just replace that o-ring? Anyone have a helms or honda parts diagram of this?
Old Aug 19, 2004 | 11:04 AM
B2FiNiTY's Avatar
#12?
I think both sides are leaking... but how can I tell if the other side is leaking too? Where would the coolant be?
I just replaced both main radiator hoses and radiator 2 weeks ago. This is giving me a huge headache.
Old Aug 19, 2004 | 11:26 AM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Why not take it back to the professional and tell them that it prematurly failed? Take your invoice.
Old Aug 19, 2004 | 11:27 AM
B2FiNiTY's Avatar
Default Re: Can brand new OEM parts go bad? (Jurassic Four)
I want to diagnose the problem first to see what parts I can buy ahead of time and get it all fixed at once.
Old Aug 19, 2004 | 11:48 AM
Jonathan_ED3's Avatar
You shouldn't have to do that though. If you paid somebody to do it, just take it back and tell them to fix it.
Old Aug 19, 2004 | 11:59 AM
93 VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">[img]
I just replaced both main radiator hoses and radiator 2 weeks ago. This is giving me a huge headache. </TD></TR></TABLE>
Ahh the plot thickens.... If you replaced the hoses it is likely that you leaked alot of coolant into the engine bay and it is slowly leaking from various crevices, splash guards, etc. Rinse down the engine and check if you still see leaks. If so, you may not have put the hoses on properly, they might be the wrong size, etc. Don't blame the guy who worked on your car 4 months ago (guessing by mileage) if you just worked in the same area 2 weeks ago.
Old Aug 19, 2004 | 12:01 PM
B2FiNiTY's Avatar
It is not from the previous hoses and radiator though. That has been a long time and most of it should have been gone by now. I have to fill up the radiator every morning because I leave puddles wherever I go.
new_climber
16
Mar 12, 2018 08:56 PM
DumaDA
Jun 25, 2011 12:50 PM
92civicx
Sep 18, 2007 07:08 AM
regdog77
Apr 12, 2007 04:44 PM
Mugen112
Aug 30, 2006 01:34 PM
