Wiring Harness
Whats up
I am doing an h22a swap into my prelude and there used to be an h23a in it and i as wondering where I would find a wiring harness for that if anyone has one or could direct me to the right place would be greatly appreciated.
thanks
Ross
thanks
Ross
Use your H23 harness. If you have a 92 Si, you will have to add 2 wire for vtec and a ground wire.
If you have a 93+ Si, you are in luck. You shouldn't have to do anything to the harness.
Hey whats up
thanks for replying but I have a question wouldnt that mean that i could use the h23 ecu? because I have both so help me out if you could.
thanks
Ross
thanks
Ross
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">i wouldnt use a non vtec ecu for a vtec engine. </TD></TR></TABLE>
you could use it, but not adviseable
Guest
Posts: n/a
Ok, Well obviously I searched and came up with NOTHING. I know this might be a stupid question but I purchased a JDM H22A motor and the wiring harness comes out on the "drivers side" which would be the passanger side in JDM LAND. So since I have a 93 USDM Si Prelude...and the wiring harness comes out on the OTHER side...Is the USDM wiring harness long enough to reach to where it needs to be plugged in??
You brought up a 20 month old thread? Your question was already answered in this thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">Use your H23 harness. If you have a 92 Si, you will have to add 2 wire for vtec and a ground wire.
If you have a 93+ Si, you are in luck. You shouldn't have to do anything to the harness.</TD></TR></TABLE>
Guest
Posts: n/a
Yeah, I brought back a 20 month old thread...AT LEAST I F-UCKING SEARCHED! I would rather post in the OLD thread than start a new one. I am tired of people ALWAYS saying **** about bringing up old stuff, then doing the same thing when people post a NEW topic that has already been covered.
My question wasnt answered in here. All I asked was: Is the H23 harness long enough to reach to the other side where it needs to be plugged in?
I understand that ^^^, But thats for wiring a USDM H22A1? A JDM H22A? I just simply asked if it was long enough...or am I going to have to extend it.
Thanks though.
Thanks though.
If you put the H23 harness on the H22a in the same manner it came off, you should not have to extend any of the engine harness/ECU harness connections. You may have to add length to maybe the Oil Pressure sending unit wire.
There are no major external differences between a USDM and JDM H22 engine which is why you don't have extend harnesses.
For what it's worth, good job on searching, I just typed "You brought back a 20 month old thread", because the question was answered in the thread, maybe just not in the terms you wanted it in.
Any other questions? Use your axles, use the H22 ECU, make sure you are wired for VTEC, connect all your grounds, check all your vacuum lines are connected right. Should fire up.
