Noob wants to know suspension swap options for EG coupe?
What are my options for a low cost suspension upgrade for front and rear? I've heard that I can convert the rear to disc from an Integra. Which year Integra, and what parts would I need?
Any other recommendations would help.
Thx.
Thx.
I know for sure that '94-up integra rear brakes will fit.
Also rear discs from a '92-'95 civic si will work.
Get the entire rear trailing arm, brake lines and e-brake cables.
I have rear disks from a 2000 Civic Si on my EG (it's for sale, see sig), you just have to use 94+ Integra lower control arms. Other than that they bolt right up!
[QUOTE=Slopoke]
im not sure about fitment but even newer si rear discs, i would stick w/civic breaks as oposed to integra because of the bult patern, you wont want different bult pattern on fornt and back it will b hard 2 shop for rims,
older integras have the same tho, not sure what year integras and not completly sure of it.
All Integra bolt patterns are the same, except for the type R because its 5 lug.
86-01 teggy is 4x100
80-96 civic is 4x100
Civic SI hatchback has the 5x114
I believe the type R is 5x114?
Bolt pattern info came from these websites:
http://www.discountedwheelware...e.cfm
EDIT: I'm actually pretty sure ALL years of civics have the same bolt pattern, unless its a special model like the SI or the Type R. Even then I think that most yeas of the SI had the same bolt pattern, not really sure though.
Modified by Ajax at 3:56 PM 8/19/2004
unknown0001
14
Aug 30, 2004 09:00 PM
