ITB's+Turbo anyone done it?
Old Aug 18, 2004 | 10:28 PM
Soccerking3000's Avatar
Default ITB's+Turbo anyone done it?
okay i recently purchased some itb's off of soccaian here on HT, and i also want to go turbo has anyone eer used itb's with a turbo setup, i was planning on making an air box, but is there any real advantage to the itb's?
Old Aug 18, 2004 | 10:34 PM
mikehawkBUiLT's Avatar
****, if you wanna go turbo then give me your itb's
never seen itb's + turbo but ****, if you wanna go turbo then give me your itb's
Old Aug 18, 2004 | 11:08 PM
Default Re: (EJcoupe)
well if this isnt going to work i will sell them to you pm'ed ya
Old Aug 18, 2004 | 11:10 PM
suspendedHatch's Avatar
I had a JDM Toyota Corolla engine, factory ITBs with an airbox. Never had a turbo though. I suppose it would help get an even amount of air to each cylinder and improve throttle response, but only slightly, and not enough to be worth the cost or trouble. Those are the benefits to NA, but boost takes care of that for you. You'd have to fabricate a box that could fit and could hold the boost. So you're talking tight fitment, and good welding.
That's what the Australians call **** value. You'd have to make a strong case to convince me otherwise.
Do it and find some good use out of it. I gotta admit the idea is pretty cool.
Old Aug 18, 2004 | 11:14 PM
wannabe_si's Avatar
Default Re: (shaundrake)
nissan pulsar gti-r's had itb's and turbo
but they where only sold in japan
check this out
http://www.gti-r.com/Vids/400bhpgtir.wmv
Modified by wannabe_si at 12:24 AM 8/19/2004
Old Aug 18, 2004 | 11:19 PM
Default Re: (wannabe_si)
ya i thought it would be different but i wasn tthinking there were going to be any special gains because of it, you no longer are using the stright though design they are best for, which of course is n/a as well but hey if anyone wants them give me a pm itb's for d16z6, if i dont go through with this that is and the price is right
Old Aug 19, 2004 | 11:30 AM
Default Re: (Soccerking3000)
bump
Old Aug 19, 2004 | 11:48 AM
CivicVX94's Avatar
ITBs=individual throttle bodies???
Old Aug 19, 2004 | 11:53 AM
Inspector Gadget's Avatar
Default Re: (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">ITBs=individual throttle bodies???</TD></TR></TABLE>
You sir, are correct!
Old Aug 19, 2004 | 11:55 AM
electronb16si's Avatar
If you actually made it possible it would eliminate the ITB's basically. If you put an air tight box around them you just turned the ITB's into an intake manifold with no fuel rail. Sell those ITB's and spend the money on a good IM.
Old Aug 19, 2004 | 12:01 PM
fakemike's Avatar
Default Re: (Shit_Bam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannabe_si &raquo;</TD></TR><TR><TD CLASS="quote">nissan pulsar gti-r's had itb's and turbo
check this out
Modified by wannabe_si at 12:24 AM 8/19/2004</TD></TR></TABLE>
Cool video! That show (Fifth Gear) is shown on SpeedVision. Two shows ever Mon. or Tues. (I forget which) at 9:00
Old Aug 19, 2004 | 12:07 PM
eL's Avatar
eL
Independent
Old Aug 19, 2004 | 12:32 PM
rodrez.'s Avatar
Default Re: ITB's+Turbo anyone done it? (Soccerking3000)
A friend of mine was using ITB's and a custom turbo kit on his built LS, back in 98. He built a custom sheetmetal plenum, and said the real difference was the throttle response, but as far horsepower/torque, he wasn't sure, as he never got the chance to dyno it. Kept blowing headgaskets, and he never trusted the butt dyno.
Old Aug 19, 2004 | 12:34 PM
95civicracer's Avatar
i have seen it on an e30 and it was badass.
Old Aug 19, 2004 | 12:43 PM
amplifi3d's Avatar
Default Re: (95civicracer)
my dad has it on his r5 turbo 2. custom throttle bodies + custom intake plenum(sp).
Old Aug 19, 2004 | 01:15 PM
98JDM_Type_R's Avatar
Default Re: (amplifi3d)
Back in the day, Scott Robinson's Honda Service Center was running ITB's turbo'd. The car was a CR-X 1.6 SOHC non-vtec back in 97-98. It was one of the first 10 Honda's to be in the high 11's low 12's. If you can find a way to pull up past issues of Sport Compact Car or Turbo, they have a close up of his engine bay. The don't mention it in the article but you can see the individuals in the picture. They were also the first to shoot nitrous through their intercooler.
Old Aug 19, 2004 | 01:21 PM
Default Re: (98JDM_Type_R)
so the concesus says sell thge itb's and get like an edelbrock or skunk2 intake mani?
Old Aug 19, 2004 | 02:56 PM
vtec.dc2's Avatar
Default Re: (electronb16si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electronb16si &raquo;</TD></TR><TR><TD CLASS="quote">If you actually made it possible it would eliminate the ITB's basically. If you put an air tight box around them you just turned the ITB's into an intake manifold with no fuel rail. Sell those ITB's and spend the money on a good IM.</TD></TR></TABLE>
agree
Old Aug 19, 2004 | 03:36 PM
TurboJesse
Guest
Posts: n/a
do you understand the idea of ITB's? It will NOT turn it into a basic intake manifold.
Old Aug 19, 2004 | 05:42 PM
rodrez.'s Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
do you understand the idea of ITB's? It will NOT turn it into a basic intake manifold. </TD></TR></TABLE>
Correct.
You will still benefit from the velocity provided by the ITB's, in fact it would probably multiply in a forced induction application.
Old Aug 19, 2004 | 05:58 PM
Default Re: (rodrez)
so i would get better velocities with the and technically more power with the itb's, it would be more efficient?
Old Aug 19, 2004 | 06:03 PM
fastludeh22's Avatar
preo stupid, but what if you split the end on the charge pipe into 4 smaller pipes running strait to each tb
Old Aug 19, 2004 | 06:42 PM
liam821's Avatar
25 Year Member
Default Re: (fastludeh22)
Skyline had stock ITB's with turbos too.
There was a big thread just like this in the archives:
https://honda-tech.com/zerothread?id=692046
and a few others i found...
https://honda-tech.com/zerothread?id=752629
https://honda-tech.com/zerothread?id=473099
https://honda-tech.com/zerothread?id=497862
liam
GrayAutoDesign
Welding / Fabrication
Sep 7, 2011 11:06 AM
simplybebop
Jan 11, 2008 05:38 PM
cxhb
Feb 18, 2006 08:20 PM
Dmc1
Jan 27, 2006 08:28 PM
^MikeG
Sep 27, 2003 03:36 AM
