Question for you SC61 owners...
Old Aug 18, 2004 | 01:41 PM
*Boostwerks*'s Avatar
Default Question for you SC61 owners...
I'm just bored, and was kinda wondering...
Do you guys hear the turbo spool when running low boost?
I just remember running 10psi with my SC50 on my stock ZC and not being able to hear the turbo spool. I think it was because at that level of boost, the wheel just wasn't spinning very fast to make a loud spool noise. On the other hand, my old T-25 setup was loud as ****! It sounded like an F16 on take off.
Old Aug 18, 2004 | 01:42 PM
Rod.'s Avatar
Default Re: Question for you SC61 owners... (Bryson)
hope to tell you this by sat
Old Aug 18, 2004 | 01:47 PM
Civic Power's Avatar
New User
When i run my sc61 at low boost ( wastegate at 7psi) i can't hear my turbo spool . But when i turn on the boost controller at 14 psi . I hear the turbo spool and it is loud . All this on a 84mm bore b16a2
Old Aug 18, 2004 | 01:55 PM
vtec69's Avatar
sure do it here it
Old Aug 18, 2004 | 02:50 PM
tthame1's Avatar
Default Re: Question for you SC61 owners... (vtec69)
I'm running 7 psi and I can't hear it at all. Just hear the open wastegate. From what I've gathered, the wheel just isn't turning fast enough at that boost level, so it makes no sound.
Old Aug 18, 2004 | 02:53 PM
Full-Race Geoff's Avatar
the t25 spun at a much higher rpm than your sc61, its all dependant on rpm of the shaft
Old Aug 18, 2004 | 02:56 PM
Default Re: Question for you SC61 owners... (tthame1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm running 7 psi and I can't hear it at all. Just hear the open wastegate. From what I've gathered, the wheel just isn't turning fast enough at that boost level, so it makes no sound.</TD></TR></TABLE>
Thats exactly what I've thought. All I heard with my old setup was the Dump as well.
I could tell exactly when I reached full boost because the tone, and intensity of the exhaust as the dump opened would change drastically.
Old Aug 18, 2004 | 02:57 PM
D-tuned's Avatar
Default Re: Question for you SC61 owners... (Full-Race Geoff)
I have SC61 at 10psi you can hear it spool from a good distance. When I turn it up to 17psi it loud as ****. I love it
Old Aug 18, 2004 | 03:07 PM
b18cx's Avatar
Default Re: Question for you SC61 owners... (2000civicsi)
At 16psi (488whp) with a open downtube, cant hear much other than the motor.
Old Aug 18, 2004 | 07:12 PM
M.A.R.C.'s Avatar
Default Re: Question for you SC61 owners... (Civic Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Power &raquo;</TD></TR><TR><TD CLASS="quote">When i run my sc61 at low boost ( wastegate at 7psi) i can't hear my turbo spool . But when i turn on the boost controller at 14 psi . I hear the turbo spool and it is loud . All this on a 84mm bore b16a2 </TD></TR></TABLE>
same thing here... except on a 77mm d16. as geoff said i'm sure it has to do with the speed at which it's spinnign
Old Aug 18, 2004 | 09:10 PM
SiRkid's Avatar
Default Re: Question for you SC61 owners... (CivicRyda2k)
need a t51r . on a supra its the loudest damn thing ever!
http://www.typsoft.com/zhugrok....mpeg
i love it.
Old Aug 18, 2004 | 09:53 PM
FredoSP's Avatar
i can hear mine @ 1 bar but then the dumbtube kills it
Old Aug 18, 2004 | 10:08 PM
FlySi's Avatar
i have an SC50 running on 7psi and i hear it... it sounds so hawt when the wastegate is closed..
Old Aug 18, 2004 | 10:16 PM
Default Re: Question for you SC61 owners... (FlySi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlySi &raquo;</TD></TR><TR><TD CLASS="quote">i have an SC50 running on 7psi and i hear it... it sounds so hawt when the wastegate is closed..</TD></TR></TABLE>
What size turbine, and what motor do you have?
I was using a .63ar on a stock internal ZC So this turbo never did spin very fast.
The smaller the motor, the slower the turbo will need to spin to create boost.
Old Aug 18, 2004 | 11:28 PM
Kwuaymaikrup's Avatar
I could hear it when it was on the dyno but when driving all I can hear is my exhaust.
karmadhi
Oct 1, 2011 04:12 PM
dcrboost
May 4, 2011 07:51 PM
Egone
Jun 27, 2004 01:41 PM
slwazgsr
Jun 23, 2003 03:45 AM
