What is a "Cold Weld"?
When you get a weld that holds together, but didn't get complete heat penetration between the 2 parts being affixed to each other, you get a cold weld. It's just a weak weld due to lack of heat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G »</TD></TR><TR><TD CLASS="quote">When you get a weld that holds together, but didn't get complete heat penetration between the 2 parts being affixed to each other, you get a cold weld. It's just a weak weld due to lack of heat.</TD></TR></TABLE>
yeah pretty much. just not hot enough, usually a quick visual way to tell it the weld is raised and roundish, where as a good weld with enough penetration is pretty flat.
huh? I always though cold weld was pretty much epoxy or some ****!? Go to kragen and as for some cold weld and they will show you bunch of epoxy's and that's what a bunch of manufacturer's call their product too! Correct me if I'm wrong though...just throwing out my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila »</TD></TR><TR><TD CLASS="quote">huh? I always though cold weld was pretty much epoxy or some ****!? Go to kragen and as for some cold weld and they will show you bunch of epoxy's and that's what a bunch of manufacturer's call their product too! Correct me if I'm wrong though...just throwing out my .02</TD></TR></TABLE>
you are correct,but the term is also used to describe a certain type of welding problem as described above.
Chris
Chris
