How/When do you guys check your oil levels?
Old Aug 18, 2004 | 12:10 PM
IloveNewt's Avatar
Default How/When do you guys check your oil levels?
I try to check my oil levek at least once a day. Sometimes i have trouble getting consistent readings. Say in the morning when the car has been sitting for the night and is dead cold the oil will read to the top dot. But say i go get gas during the day and i let it sit for 5 mins then check the oil its only at the middle between the dot.
Im just kinda worried cause there is an oil leak on the back/cam side of the engine....i think its from the cam gear seals or even maybe the headgasket...but i dunno if that would cause such variations.
Old Aug 18, 2004 | 12:14 PM
toolowsol's Avatar
Default Re: How/When do you guys check your oil levels? (MordecaiPSI)
I check my car when it is cold, and been sitting level for atleast 5 minutes
Old Aug 18, 2004 | 12:29 PM
roydogg's Avatar
Default Re: How/When do you guys check your oil levels? (toolowsol)
I check mines atleast once a week. But I look under my car everyday to make sure there are no leaks.
Old Aug 18, 2004 | 12:36 PM
krazn's Avatar
Default Re: How/When do you guys check your oil levels? (roydogg)
i check mine every day...but thats cause i have minor leaks. and i'm also a paranoid bastard. also u have variation cause ur oil is still running around in ur engine. if it sits for a while...it all goes back down to the pan.
Old Aug 18, 2004 | 12:49 PM
aznballer's Avatar
run ur car for a lil then check it, check one a week or one every 2 weeks
Old Aug 18, 2004 | 12:51 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">I check mines atleast once a week. But I look under my car everyday to make sure there are no leaks.</TD></TR></TABLE>
im always checking under my car , and i usually check it every couple days , and this is when the car has been off overnight and is before the first start in the morning.
Old Aug 18, 2004 | 12:54 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (aznballer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznballer &raquo;</TD></TR><TR><TD CLASS="quote">run ur car for a lil then check it, check one a week or one every 2 weeks</TD></TR></TABLE>
?? thats stupid , if you run your car you wont get an accurate reading as the oil will be all in the motor.
IloveNewt's Avatar
Why run my car then check? Shouldnt one check in the morning after its been sitting a while to get a good reading when the oil has all drained to the bottom?
Old Aug 18, 2004 | 01:24 PM
Turbo E's Avatar
as long as its between the two dots its all good.
Old Aug 18, 2004 | 01:33 PM
beepy's Avatar
Default Re: (Turbo E 604)
I check the car cold, and I fill up the oil to just a little bit above the "full" line, to account for the oil in the turbo and lines.
Old Aug 18, 2004 | 01:47 PM
Rod.'s Avatar
Default Re: (beepy)
I am always paranoid. I try to check it everytime it has cooled down. If I see a spot in the drive way I will go check it again.
Old Aug 18, 2004 | 01:54 PM
XiiiXiii's Avatar
Proper way to check oil is when the car has warmed up, NOT when it is cold.
Old Aug 18, 2004 | 01:55 PM
vtec69's Avatar
usally once a day before I go to work and after I come home sometimes depending on how much i beat on it
Old Aug 18, 2004 | 01:59 PM
motioncamaro's Avatar
I check mine when it's hot & running. This way I know the oil filter is full & I want the level proper when running.
Old Aug 18, 2004 | 03:15 PM
T-RO's Avatar
I check mine after I get CEL 22 or my Oil Pressure gauge stops working...
Old Aug 18, 2004 | 07:52 PM
IloveNewt's Avatar
Default Re: (T-RO)
ok so which is it? When its warm or when its cold? The thing is, for those who say to do it when its warm, how do you know that when the engineers at honda were designing the engine, that they didnt take into account the amount of fluids that would remain in the filter and whatnot, therefore designing the dipstick tyo take this into consideration?
Old Aug 18, 2004 | 09:08 PM
Tchleung's Avatar
my god.. the PROPER way is to check when the engine has been warmed. it's even in your manual
gwarfare
Feb 19, 2013 01:58 PM
Red-Rag-B18
Jun 12, 2010 02:20 PM
IloveNewt
Jan 11, 2004 02:10 PM
B18Redline
Jun 10, 2002 11:35 AM
Rah Rah
Feb 1, 2002 10:19 PM
