swap help
Old Dec 2, 2001 | 03:23 PM
STK B16's Avatar
Default swap help
ANyoen Located around Santa Clara, CA area that can help me on my swap.. i finish the swap.. but the car is havin some probs.. idles fine. but when i step on the gas pedal it dies.. Checked my plugs, wiring but still cant figure it out. email me me if u can COme out and take a look and help me.. thanks..
Old Dec 2, 2001 | 06:52 PM
Mugen Dom's Avatar
Default Re: swap help (Json79)
is the timing set correctly? maybe vacumes
Old Dec 2, 2001 | 06:59 PM
STK B16's Avatar
Default Re: swap help (jdmB18hatch)
its ideling fine.. but once i try to step on the gas pedel it dies.. but if i step on it lightly the rpm raise.. but the deeper i step it, it dies
[Modified by Json79, 8:01 PM 12/2/2001]
Old Dec 2, 2001 | 07:02 PM
Mugen Dom's Avatar
id have to see it but i dunno check all the wies on it make sure everythink is the way it should be thats wut id look at first
Old Dec 2, 2001 | 07:04 PM
STK B16's Avatar
yea i wish someone around here can help me.. i want my car rnning.. already.. i been waitin so long for this
Old Dec 2, 2001 | 08:27 PM
akachef's Avatar
New User
what's the swap?
Old Dec 2, 2001 | 08:41 PM
STK B16's Avatar
Default Re: swap help (akachef)
b16a3 running p30 ecu.. into a 90si hatch
Old Dec 2, 2001 | 11:43 PM
One8Hatch's Avatar
New User
are you using the non obd distributer and injecors? would that cause the prob.?
Old Dec 3, 2001 | 01:59 AM
brad.'s Avatar
Default Re: swap help (One8Hatch)
hmmm...sounds like its not enough fuel.....check your injectors, also the fuel pressure reg.
Old Dec 3, 2001 | 08:38 AM
STK B16's Avatar
Im using obd1 injectors.. everything that came off of a 94 delsol...
Old Dec 3, 2001 | 08:54 AM
STK B16's Avatar
oH yea i still have a half tank of regular octane fuel in my car from the last stock engine.. i didnt put any new gas .. could that be the prob?.. Should i go get premium or a octane booster?
Old Dec 3, 2001 | 09:35 AM
markedOO1's Avatar
...the last time I had that problem was w/ my zc and it was the igniter....
Old Dec 3, 2001 | 08:44 PM
STK B16's Avatar
Default Re: swap help (marked001)
mark,
did ur car even start up when this happen?
Old Dec 4, 2001 | 04:13 AM
Red Civic T's Avatar
New User
Won't jsut be the gas, so forget that thought....
95civickid
Mar 20, 2005 06:32 PM
civictunr_ls
Feb 10, 2005 05:16 AM
FLIPboi
Aug 29, 2002 07:16 PM
STK B16
Dec 7, 2001 01:49 PM
