DID SEARCH, NOT SPECIFIC?????
Ok i did a search but i want specific info. see sign for setup. i figure compression to be at or aroud 10.4:1. i was told the higher compression the colder the plug you want. is this true? also should i run platium, or copper, or iridium? any help would be great. thanks in advance
surprised no one has helped you with this, a colder plug can be found at zex, but thats to prevent detonation... retard timming and a polished pistions, which is coated should'nt have this problem... you did spend the extra 25-35 mins and work your pistons right.......
ohh.. i see in your sig.. hehe
" stage 1 port and polish on head " post up some pics, i want to see what a stage one looks like.
sorry no pics, but i dont think it is a stage 1, a friend of mine works at a machine shop and they did it there. i belive it is larger than a stage 1. but my real ? is do i need a colder plug also if not then which is best for my setup, copper-platium-iridum. sorry bout spelling. retard ign timing or cam timing????
96tegsr
12
Dec 19, 2004 07:06 PM
Fab-Works
Mar 30, 2004 10:10 AM
Blazin Si
Feb 24, 2004 01:43 PM
