Talon Fuel Injector to Honda B16A2
Old Aug 18, 2004 | 07:32 AM
Binary's Avatar
Default Talon Fuel Injector to Honda B16A2
Can you use the Talon fuel injectors and put then into B16A2 motor?
The talon injectors are 440cc.
If so is their anything else i have to do to get them working?
Old Aug 18, 2004 | 07:34 AM
DaX's Avatar
DaX
Loved
Community Favorite
They are [I think] low impedance. You will need a resistor box.
Old Aug 18, 2004 | 07:37 AM
Binary's Avatar
Default Re: (DaX)
where do i get a resistor box?
Old Aug 18, 2004 | 07:38 AM
DaX's Avatar
DaX
Loved
Community Favorite
eBay, your Honda dealer, HT classifieds, junk yard...lots of places. What kind of car is it? If it's an OBD-0 civic you probably already have one.
Old Aug 18, 2004 | 07:40 AM
Binary's Avatar
Default Re: (DaX)
It's Honda Civic SiR/Si 2000.
Old Aug 18, 2004 | 07:43 AM
DaX's Avatar
DaX
Loved
Community Favorite
You'll need a resistor box then. Are you just plugging these in while running a stock ECU?
Old Aug 18, 2004 | 07:58 AM
Binary's Avatar
Default Re: (DaX)
yeap.. my buddy is give me the injectors because I keep getting Fuel To rich (bank 1) Engine ceck. And I already put new oxgen sensor, got a different type of fuel pressure regulator, and used fuel injector clear for Honda. and still the light so I want to test the Injectors with out buying any thing so that why I want to use talon is because i got them for free....
Old Aug 18, 2004 | 08:09 AM
DaX's Avatar
DaX
Loved
Community Favorite
Well if you're getting a fuel too rich code, these sure as hell aren't going to fix your problem.
Stock injectors = 240cc
These = 440cc
This is just compounding your problem...bigger injectors on stock computer means more fuel is dumped. You probably have an injector stuck open...Try replacing your injectors with another set of stock civic injectors.
Old Aug 18, 2004 | 08:14 AM
DruWO's Avatar
Default Re: (DaX)
they're 450cc's....
yeah...you should 'atleast' get a afc to control these injectors. And if you're ghetto like me, you can just get the resistors from radio shack and wire them inline.
you're also going to have to bore out your O-rings a little so the injectors sit well in the IM..
Old Aug 18, 2004 | 08:17 AM
EE_Chris's Avatar
Default Re: (DaX)
Whats your setup Binary?
As DaX mentioned, if you're getting a code for 'too rich' and you're going to simply drop these in and expect that this alone would cure your problem - you're going to be disappointed.
As DaX also mentioned, these will require a resistor box or at the very least some 10ohm, high wattage resistors from Radio Shack or the like.
Old Aug 18, 2004 | 09:07 AM
Binary's Avatar
Default Re: (EE_Chris)
- 2000 B16A2 Motor
- Stage 3 Clutchmaster Clutch
- Lightweight Flywheel aslo by Clutchmaster
- AEM Cams gears ( came with the car)
- I think stage 1 cam saft ( came with the car )
- and Short Arm Intake ( came with the car )
- Thats it on the engine part...
Old Aug 18, 2004 | 10:04 AM
illi Adik's Avatar
Default Re: (Binary)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Binary &raquo;</TD></TR><TR><TD CLASS="quote">- 2000 B16A2 Motor
No need for the 450's entirely too much fuel. I would just keep the stock civic Injectors and get a VAFC for the time being if you are pressed for cash or get some 270's/310's and some form of EMS.
billy hoang
Northeast (Sales)
Feb 17, 2011 10:11 AM
billy hoang
Northeast (Sales)
Dec 6, 2010 09:33 AM
spooolin
Oct 13, 2006 07:48 AM
UrMyI3itch
May 2, 2003 01:02 PM
