radiator help! 95 lude
Old Aug 18, 2004 | 01:20 AM
VtecPrelude95's Avatar
Default radiator help! 95 lude
hey wussup guys...under my hood i see a splash of antifreeze neear the cap area and tube. everytime i clean it up..after awhile it does it again..seems like its leaking but theres no hole i see...is it just the tube or do i need a new cap...the temperature stays the same and the car never over heats... in the radiator theres always antifreeze, but the in the resovoir for it its always a lil low when i fill it up...thanks for the help!
95 Prelude Vtec (h22a1)
Old Aug 18, 2004 | 01:31 AM
OEM_ASSASSIN's Avatar
Default Re: radiator help! 95 lude (VtecPrelude95)
Check to see if the radiator is corroded where the hose is attached. Mine kept doing this and I found it was starting to become brittle and rot out. My radiator was plastic by the way.
Old Aug 18, 2004 | 04:55 PM
nota944mechanic's Avatar
check for cracks while the radiator is still hot. its easier to see them when its hot. sometimes you can watch the coolant seeping out. also if you can borrow a coolant pressure tester from someone you can pressurize it and chase down the leak. hope this helps.
Old Aug 18, 2004 | 06:45 PM
Jagan'92's Avatar
The tube from the neck to the overflow tank is cheap, and the oem cap is cheap - why not replace both, get some new hose clamps for the little tube, and see if that solves it. When my radiator went out, there was a hairline crack right at the bottom of the neck.
Old Aug 18, 2004 | 08:04 PM
Yield's Avatar
The upper plastic end tanks are notorious for cracking in 4th gens. You won't see it because it is a hairline crack. If you have the engine warm and running and then look you may find the place where it is leaking out. Some people have tried to fix it with limited success, the best solutin is to replace it. They're only $140 or so.
Old Aug 19, 2004 | 01:09 AM
thanks...ill take the advice and see if it solves it!
Old Aug 19, 2004 | 01:31 AM
rkonfire's Avatar
Yeah, look for a hairline crack right around the neck area.
Old Aug 19, 2004 | 07:47 AM
BrokeLude's Avatar
Default Re: (rkonfire)
If you end up replacing it, have them put in an all metal radiator...
Old Aug 19, 2004 | 08:01 AM
AndyD's Avatar
Default Re: (BrokeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">If you end up replacing it, have them put in an all metal radiator...</TD></TR></TABLE>
Why??
Just get an OEM replacement radiator that comes with a lifetime warranty for $128 shipped to you.
That's what I did.
Old Aug 19, 2004 | 08:03 AM
BrokeLude's Avatar
Default Re: (AndyD)
That's a good option, but eventually you will be pulling that thing out to change it again even if it's free to replace (considering you find the receipt). JMHO
slikz714
Jul 12, 2006 03:40 AM
BlazingSoul
Nov 6, 2005 12:53 PM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
projectM
17
Feb 14, 2003 12:53 AM
bb2prelude
Nov 23, 2002 06:19 PM
