b18 into a CRX shell then turboed? how possible?
Old Aug 17, 2004 | 11:50 PM
djnikko's Avatar
Default b18 into a CRX shell then turboed? how possible?
I have a CRX with a ZC engine, wanting a b18? how easy is this? cheers
Old Aug 18, 2004 | 08:16 AM
JDMotive's Avatar
Default Re: b18 into a CRX shell then turboed? how possible? (djnikko)
Its not hard at all.Swapping the b18 in is as easy as swapping the zc in,just requires a engine mount kit and a cut integra shift linkage.There are turbo kits out for that swap,or you could piece together your own.
Old Aug 19, 2004 | 03:00 AM
djnikko's Avatar
Default Re: b18 into a CRX shell then turboed? how possible? (JDMotive)
nice, thanks for the reply mate. I have a ZC in the car at the moment (euro spec)
Does anyone know any good sites for engine mounts? Can I use stock b18 engine mounts or is it best to go aftermarket?
Thanks in advance
Old Aug 19, 2004 | 07:16 AM
JDMotive's Avatar
Hasport is the best motor mount company out. http://www.hasport.com/
Old Aug 19, 2004 | 10:45 PM
djnikko's Avatar
thanks mate
but how come the mounts are so expensive? Is there a ghetto way of going about this? Can i not use the stock B18 engine mounts and weld them in the engine bay? I heard a few people have to do this for the b16 swaps..
Thanks
Old Aug 20, 2004 | 10:30 AM
pgpunkguy's Avatar
you COULD weld em in...
but like you said, it would be ghetto...
personally, i would just go with the hasport mounts... (they're good )
Old Aug 22, 2004 | 06:15 AM
djnikko's Avatar
Default Re: b18 into a CRX shell then turboed? how possible? (pgpunkguy)
This is the first engine swap ive done, will i need to find a b18 which is obd0 to make wiring easier? or does that not matter?
Thanks in advance
Old Aug 22, 2004 | 06:32 AM
turboimports's Avatar
The setup you are thinking about doing is more than possible. Try Place Racing and Hasport for motor mounts and other related swap items. Hasport has good info and a swap guideline for the different engine swaps. You will probably need shift linkage, mounts, axles, ecu, engine, tranny, wiring harness. There may be more that I forgot to mention.
To turbocharge a CRX, and still have room will also take time. You will or should move the battery to the rear. Get like a battery relocation kit on Ebay or something. You can also get slim/thin fans, use a 92-95 EG radiator, preferably one from the delsol dohc vtec. You can also remove A/C, lines, fan, condesor, etc. to make more room for piping and intercooler. You will also have to be carefull about wich manifold you pick out...Big manifolds built for drag will not be so easy to fit in your chassis cause of radiator clearance issues. Just choose what you can get wisely and you'll be fine. Don't be afraid to take measurements.
-Lor
CRX_SedanED4
Jul 24, 2008 08:27 AM
svacca1
Nov 16, 2007 08:49 PM
twilightprotege
Welding / Fabrication
Jul 9, 2006 05:19 AM
RSvtec
Apr 27, 2006 08:55 PM
1hotcivicSi
Jan 28, 2004 03:25 PM
