need sum info.
Old Aug 17, 2004 | 07:00 PM
BadEH2's Avatar
Default **CATALYTIC CONVERTER REPLACE**
ok, well im going to replace my cat. converter tom, morning, should i do nething, to make it easier for me to take the stock 1 off?!? ne tips tricks..?
Old Aug 17, 2004 | 07:09 PM
BadEH2's Avatar
Default Re: **CATALYTIC CONVERTER REPLACE** (Bad_EG6)
bump..*****
Old Aug 17, 2004 | 07:10 PM
shamoo's Avatar
Will you make something up for me please?
There are no tips or tricks. Basically remove your old one and put the new one in.
You might encounter some tight/rusted bolts, however. Try to pick up some Liquid Wrench or some other penetrating fluid so you can remove the bolts without stripping/shearing them off.
Other than that, everything is straightforward. Good luck.
EDIT: If you don't have access to a compressor/impact wrench, try to use a 6 point socket, NOT a 12 point socket. You have a less chance of stripping it when you use a 6 point one. Same thing, even if you are using an impact wrench. Use the 6 point impact sockets.
If you don't have sockets and only have a ghetto adjustable wrench or something, don't even attempt it. It's going to strip in about 2 seconds and then you'll have to cut the bolts.
Old Aug 17, 2004 | 07:11 PM
BadEH2's Avatar
Default Re: **CATALYTIC CONVERTER REPLACE** (shamoo)
thanks dude. i was just makin sure!
Old Aug 17, 2004 | 07:12 PM
Luserkid's Avatar
Mine was welded on on the back. Zawsall is your friend at times like that.
Old Aug 17, 2004 | 07:15 PM
BadEH2's Avatar
LOL, i dont have a impact wrench, but i dont have that stupid adjustible wrench either, but i do have socket wrenchs and a few regular wrenchs, im going to try to find a breaker bar from a friend or sumthing.
Sivic90
Nov 27, 2008 04:38 PM
Acidcrakker
Mar 3, 2008 08:46 PM
LaOstha
Sep 1, 2006 02:32 PM
asdfgh
Sep 28, 2005 04:46 PM
1998teg
Jan 1, 2005 01:27 PM
