95 b18b into a crx.. HELP
Old Dec 2, 2001 | 01:30 PM
pg_thao's Avatar
Default 95 b18b into a crx.. HELP
i recently swap a 95 ls motor to my crx hf, using a b16 distributor, and a ls ecu, the problem is that the car stalls from 1-5k, and also when a wot it stalls and dies out, what can i do?
Old Dec 2, 2001 | 02:39 PM
sgT's Avatar
sgT
Default Re: 95 b18b into a crx.. HELP (pg_thao)
First of all, you should use an LS distributor because you are using the LS ecu.
Second, is the check engine light on?
Old Dec 2, 2001 | 03:22 PM
One8Hatch's Avatar
New User
Default Re: 95 b18b into a crx.. HELP (sgT)
did you covert to ob1 or stay non obd? if your staying non obd, make sure you have the 91 teg distributer, ecu and alternator,
Old Dec 2, 2001 | 05:40 PM
pg_thao's Avatar
Default Re: 95 b18b into a crx.. HELP (One8Hatch)
if im using the b16 distributor, can i use my b16 ecu and stay nonobd
Old Dec 2, 2001 | 07:34 PM
sgT's Avatar
sgT
you cant use a b16a ecu if u dont have a b16a
benvtec
Jun 9, 2005 10:08 PM
89silverb16crx
Mar 18, 2004 10:10 PM
JSPEC4DR
Feb 23, 2003 12:44 PM
pg_thao
Dec 4, 2001 01:54 PM
pg_thao
Dec 2, 2001 03:20 PM
