h22a7 wiring diagram needed
Old Aug 17, 2004 | 05:14 PM
zeejermons's Avatar
Default h22a7 wiring diagram needed
i am in need of an h22a7 year 2000 wiring diagram. All anyone has is the 92-96 h22 wiring diagrams. I am using an LS integra 1994 harness to wire it up, and i need to figure out three things. I've got a 3 wire IACV and the ls harness only has a plug for a 2 wire one. There is a plug in the cylinder wall under the IM but above the oil filter, it's not the knock senso, because that is below the oil filter, this is a plug that goes right into the block, and i don't know what it is, there is no plug for it from the LS harness and there is no name for the plug in the 92-96 prelude diagrams. Last but not least, there is a 4 wire plug that goes straight down along the timing belt side and goes into the block through the bottom corner, and i definitely did not have this on my LS block, so i don't know what that's all about either. can anyone offer some help plz? thanks.
Old Aug 17, 2004 | 05:50 PM
v4lu3s's Avatar
RTFM
the 4 wire plug by the oil pump is your crank angle and TDC sensors.
and for the iacv...which ecu are you using?
Old Aug 18, 2004 | 08:37 AM
zeejermons's Avatar
Default Re: (v4lu3s)
well i just swapped to an OBDI distributor.. so i guess that TDC sensor doesn't matter anymore does it? umm i'm using a P13 ecu.
sh!ft
27
Sep 12, 2014 04:59 AM
coltonbarrier
Oct 30, 2013 07:25 AM
Marvin1985
Jul 7, 2013 02:21 PM
clockstick
Oct 27, 2009 06:54 PM
j spec
Jul 30, 2006 04:57 PM
