car trouble
Old Aug 17, 2004 | 03:53 PM
andydik's Avatar
Default car trouble
alright first off the car is a 91 civic std with a b18b the car was running fine until one day i tried to start it and the battery was dead so i charged it and it started right up so i dove it around then came home later and then the next day the battery was dead again so i charged it again and it started up so i went for a drive again and i noticed that the my head lights would go dim and woulding work same with my blinkers and every thing else so i figered my altenator was bad so instead of buying a new one i found one in my shop i didint now if it was good or not but i went ahead and tried it so after i put in the mystery altenater in. the car wont start none of the lights work .when i push my hazzard lights on all the signals in my gauge cluster light up and it makes a wied noise it also does the same thing when i turn on the blinkers i went through all my wireing every thing seem good do you think it all because the mystery altenator iny help on this would be grate thanks
Old Aug 17, 2004 | 04:25 PM
eda6's Avatar
Default Re: car trouble (andydik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andydik &raquo;</TD></TR><TR><TD CLASS="quote">a 91 civic std with a b18b started until i put in the mystery altenater in.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andydik &raquo;</TD></TR><TR><TD CLASS="quote">iny help on this would be grate thanks</TD></TR></TABLE>
get a new ALTENATER
Old Aug 17, 2004 | 07:16 PM
Gumbey75's Avatar
might of burn some of ur fuses... my hazards make a welder noise.... new alternator would be good but check fuses too.
Old Aug 17, 2004 | 07:18 PM
leth's Avatar
Default Re: car trouble (Gumbey75)
check the fuses in the black box in the engine bay. it sounds like a fuse.
BLKOUT23
16
Nov 10, 2015 11:08 AM
Eg Fool
19
Sep 12, 2009 07:28 PM
end005
Dec 31, 2007 06:33 AM
unclebenwho
Apr 11, 2006 12:19 PM
CLICC916
Oct 17, 2001 10:58 PM
