h22 swap ecu problem
i'm doing an h22 swap into a 92' accord coupe...i know im supposed to add the following wires to the P13 ecu:
-IAB control soleniod...into pin# A17 (Consist of two wires)
-Knock sensor into pin# D3 ( one wire)
-V-Tec pressure switch into pin#D6 ( two wires)
-V-Tec valve into pin# A4 (one wire)
each one of these is assigned to one pin even if they have two wires...for example..the IAB control & the V-Tec pressure switch...which wire do i pug in to where?
im not worried about the knock sensor or the v-tec valve...only one wires comes out?.....please help soon
thanks
Modified by type-t at 7:43 PM 8/17/2004
thanks
azzinine1
Jan 11, 2005 07:58 PM
