VAFC I/H/E Q?
Old Aug 17, 2004 | 01:05 PM
r0cket247's Avatar
Default VAFC I/H/E Q?
I have SEARCHED for an answer to this question, to no avail. so please don't flame on.
I have a 97 B18c{r} in my 97 Civic Dx Coupe running the jdm obd2 ecu. My mods are: 4-1 JDM ITR Header, 2.5 Carsound Cat. , 2.5 Piping, Skunk 2 Cam Gears, B&M FPR, and Apexi VAFC.
I wanted to know if I would get any horsepower from tuning I/H/E/CG/FPR/VAFC ? Is it worth paying $100 bux plus to tune it? I don't want to go obd1 (w/ the kenji chip) ... will I see any gains (i know i know)?
Bottom line: is it worth tuning?
Thanks, please don't flame, I've spent hrs searching w/ my 56k thru treads ... no luck
Old Aug 17, 2004 | 01:12 PM
Willard's Avatar
Default Re: VAFC I/H/E Q? (r0cket247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r0cket247 &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to know if I would get any horsepower from tuning I/H/E/CG/FPR/VAFC ? </TD></TR></TABLE>
Yes.
https://honda-tech.com/zerothread?id=511707
toss the fpr
tune the car on a dyno with a wideband o2 sensor.
Bbasso's Avatar
If you tune you will get better MPG at the least.
that there is worth the $100.
You should see some extra power when tuned- if not a smoother power band will be noticed.
Old Aug 17, 2004 | 01:13 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Hit a dyno and tune it yourself if you can.
Old Aug 17, 2004 | 01:14 PM
jdmspoonitr's Avatar
Dude. Yes it is worth tuning. Austin tuned my car and I gained up to 20 whp in some places. Most of the gain was 4-6000, but the powerband was smooth all the way to the top. Tuning is key. 100 dollars is nothing.
Old Aug 17, 2004 | 01:17 PM
r0cket247's Avatar
Default Re: (Rguy)
thanks .. yall
Old Aug 17, 2004 | 01:47 PM
itr1244's Avatar
Default Re: VAFC I/H/E Q? (Willard)
willard. do you mind to share your settings for stock motor B18C5 with I/H/E?
Old Aug 17, 2004 | 01:51 PM
Willard's Avatar
Default Re: VAFC I/H/E Q? (itr1244)
header/cat only here... (intake/exhaust = not for me)
vtak has been moved.
WOT settings:
Starting from negative @ ~6000rpm... and getting more negative up till redline.
Partial settings:
Zero (b/c obd2 self corrects)
your settings will vary per your mods and changes should be done by a qualified tuner on a 'good' dyno with wide band sampling.
Old Aug 17, 2004 | 11:40 PM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">header/cat only here... (intake/exhaust = not for me)
WOT settings:
Partial settings:
your settings will vary per your mods and changes should be done by a qualified tuner on a 'good' dyno with wide band sampling.</TD></TR></TABLE>
alright.. thanks.
Old Aug 18, 2004 | 11:53 AM
white rocket's Avatar
Sorry to invade on this thread. itr 1244, that has got to be the best sig I have ever seen. I'm high like a **** chillin at work. I think I'll drag my accountant over to my desk for a session now.
To make my invade relavent, I too I'm thinking about a VAFC after I get the DC JDM SS 4-1 with a hi-flow cat and full T1R catback. Hondata just seems to be so much more $$$$$.
VTECU
Nov 14, 2006 11:07 PM
Bbasso
Jan 20, 2005 02:11 PM
itr1244
Jun 15, 2004 01:04 PM
B18C5-EH2
Feb 17, 2003 08:13 PM
ITR 01-0840
Jan 7, 2002 04:59 PM
