Spark plug wires
I just bought a set of Arospeed 9.2mm spark plug wires for my all stock 91 Civic D15B1. My factory wires are not bad, but I just wanted a reasonable upgrade. I got a good deal on them, not the 50+ dollars off the website. Here is the issue: the metal connector for the distributor on two of the wires doesn't hold on the distributor cap, but the other two do. I can possibly reshape the ends with pliers. Second, The rubber cover around the wire that caps the area around the hole in the valve cover is a universal I guess because it is able to move up and dwn the wire. Even when it is down it doesn't seem to provide the same degree of seal that the factory wires do. I regularly wash the engine bay and I rely on those seal points to prevent the water from seeping down to the plugs. Is this an issue? Anyone with these wires and no problems?
My overall point of this post is the following:
Is a larger size of wire better?
If so, why?
If not, why and what are the disadvantages? Any long term damage possibilities?
I have not run my car with these wires on yet, so I need the info before I do.
BTW, if it matters, my plugs are the manual recommended NGKs with about 15K on them.
If so, why?
im not exactly sure myself but the best way to get awnsers fast when you got a stock motor is get a hanes manual. they have everything from changing your oil to a complete engine rebuild.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnclaunch »</TD></TR><TR><TD CLASS="quote">Why is it that everyone can post ways to help a member repair carbon fiber, but no one can answer questions about spark plug wires. WTF!?</TD></TR></TABLE>
Your question has been asked so many times that it's not an interesting subject anymore.
Use the damn search button.
Search for "firing order".
Click the archives button.
You WILL find your answer.
I did the search myself and found it answered many times.
Now it's your turn.
Now it's your turn.
johnclaunch
Aug 16, 2004 11:15 PM
shivic
Jan 4, 2004 04:36 PM
