H23 compression results..
Old Aug 17, 2004 | 04:45 AM
delguiner's Avatar
Default H23 compression results..
hey guys i just got a compression test done and it read 210 across the board? what does that mean? i know the #'s are pretty high... someone said i have a lot of carbon build-up... any other suggestions?
Old Aug 17, 2004 | 04:49 AM
Behan's Avatar
Default Re: H23 compression results.. (delguiner)
It could be carbon build-up, but it would be unlikely that all 4 cyl's have the same amount of build up.
210 psi is definetly high for an h23.
Old Aug 17, 2004 | 05:12 AM
delguiner's Avatar
Default Re: H23 compression results.. (Behan)
any suggestions on what to do? i mean the car is running well...
Old Aug 17, 2004 | 05:55 AM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions on what to do? i mean the car is running well...</TD></TR></TABLE>
nothing...what are you worried about?
Old Aug 17, 2004 | 06:34 AM
delguiner's Avatar
Default Re: H23 compression results.. (H23 Power)
im just worried about all that carbon.... should it be cleaned?
Old Aug 17, 2004 | 06:40 AM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner &raquo;</TD></TR><TR><TD CLASS="quote">im just worried about all that carbon.... should it be cleaned?</TD></TR></TABLE>
i highly doubt there's that much carbon on there, you probably just have a good running motor, the numbers aren't that high
Old Aug 17, 2004 | 06:43 AM
delguiner's Avatar
ok well a couple of ppl told me they were a little high.... but the compression test was done with a canadian tire 40$ tester.... so....
Old Aug 17, 2004 | 09:45 AM
SKDRCR's Avatar
you can always get some combustion chamber cleaner or some
seafoam. run it through there and that **** should smoke out.
the do another compression check and see what comes up.
Old Aug 17, 2004 | 09:49 AM
LudeyKrus's Avatar
Don't get rid of the carbon!
Keep the compression as high as you can get!
Old Aug 17, 2004 | 12:44 PM
Behan's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Don't get rid of the carbon!
Keep the compression as high as you can get! </TD></TR></TABLE>
exactly, more compression = more horsepower.
If it ain't broke, don't fix it.
Old Aug 17, 2004 | 12:46 PM
Yield's Avatar
Default Re: (Behan)
Ya, heavy carbon buildup is a great thing for your engine
Old Aug 17, 2004 | 12:53 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yield &raquo;</TD></TR><TR><TD CLASS="quote">Ya, heavy carbon buildup is a great thing for your engine </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan &raquo;</TD></TR><TR><TD CLASS="quote">
If it ain't broke, don't fix it. </TD></TR></TABLE>
Old Aug 17, 2004 | 01:23 PM
delguiner's Avatar
Thanks for the Advice boys!
Old Aug 17, 2004 | 01:44 PM
prelittlelude's Avatar
you should be happy with the numbers and not worry, when the motor needs attention from too much carbon you will know, leave it alone its doing great
alex@killian.com
Jul 13, 2007 06:19 AM
lude98SH
Jun 6, 2006 06:31 AM
Xbstd23X
Oct 3, 2004 09:30 PM
del_parker
Sep 24, 2003 08:57 PM
ixcryxblood
Jun 23, 2003 06:19 AM
