VSS and tach dont work
Old Aug 16, 2004 | 09:06 PM
ham's Avatar
ham
Default VSS and tach dont work
i have a jdm cluster in my 4dr b16 and the tach and speedo dont work. any quick checks i can do on the sensor / ECU to narrow down the problem ?
is there any way to manually run wires off the back of the cluster to the ECU in case of bad wires? ( i think this may be the issue because the VSS is getting power and ground)
i have no code because I have a chip for 1 wire vtec.
any help is appreciated.
Old Aug 16, 2004 | 10:15 PM
GTA's Avatar
GTA
Default Re: VSS and tach dont work (ham)
srry cant help you there.......My speedo seems likes its reading wrong....i had a 0bd2 vss switched it to a 0bd1 vss cause my cars a 92-95 civic... seems like im going so slow compare to the speed im reading on the speedo. if anyone knows about this problem too "lend me your knowledge master"
Old Aug 17, 2004 | 05:37 AM
ham's Avatar
ham
bump please
Old Aug 17, 2004 | 12:50 PM
ham's Avatar
ham
civichatch2307
Aug 7, 2007 07:06 PM
chulopilong
Feb 16, 2005 03:04 PM
hndakd
Nov 16, 2004 03:57 PM
JiVe
19
Jul 22, 2003 01:12 PM
crxtreme27
Jun 22, 2003 10:34 PM
