VSS and tach dont work
i have a jdm cluster in my 4dr b16 and the tach and speedo dont work. any quick checks i can do on the sensor / ECU to narrow down the problem ?
is there any way to manually run wires off the back of the cluster to the ECU in case of bad wires? ( i think this may be the issue because the VSS is getting power and ground)
i have no code because I have a chip for 1 wire vtec.
any help is appreciated.
Re: VSS and tach dont work (ham)
srry cant help you there.......My speedo seems likes its reading wrong....i had a 0bd2 vss switched it to a 0bd1 vss cause my cars a 92-95 civic... seems like im going so slow compare to the speed im reading on the speedo. if anyone knows about this problem too "lend me your knowledge master"
civichatch2307
08-07-2007 07:06 PM
crxtreme27
06-22-2003 10:34 PM
