need to "un tig"
Old Aug 16, 2004 | 08:15 PM
prelude994e's Avatar
Default need to "un tig"
am changing my BOV and i wanna try to untig the whole flange so i can provide the next person to own this with a simple weld on flange.......
do i go abotu burning the weld joints very carfuly, i know it wont be crazy clean but dealable.....or is there a special tool to do this, i am familiar with migin and tigin machines and diff temps and gases but i just wanna get this done rifght way..........gogin to see welder on thursday but wanna know what im in for...thanks guys
Old Aug 16, 2004 | 10:09 PM
Blindstuff's Avatar
Default Re: need to "un tig" (prelude994e)
I THINK you can just put really high amperage to the welding point and melt it off, but it would look like ****
Old Aug 16, 2004 | 11:28 PM
paulzy's Avatar
just bring charge pipe to a machine shop and they'll cut it off with a plasma cutter
Old Aug 17, 2004 | 01:28 AM
Thinkmoto's Avatar
Default Re: (paul vang)
cut off with a die grinder or cut off wheel. Plasma cutters will leave slag just like a torch.
Old Aug 17, 2004 | 05:47 AM
david@didrace.com's Avatar
You need to keep the flange but not the intake piping? You can use a Tig torch to melt off the piping but unless you have a really steady hand it would be easier to use a die grinder/cut-off wheel/Dremel like stated above.
Old Aug 17, 2004 | 05:35 PM
jimbeamsEK's Avatar
Default Re: (Thinkmoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thinkmoto &raquo;</TD></TR><TR><TD CLASS="quote">cut off with a die grinder or cut off wheel. Plasma cutters will leave slag just like a torch.</TD></TR></TABLE> not if you know what your doing.
Old Aug 17, 2004 | 05:46 PM
Luserkid's Avatar
Default Re: (jimbeamsEK)
HackSaw or Zawsall will cut that off no problem.
Old Aug 18, 2004 | 01:26 AM
Thinkmoto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimbeamsEK &raquo;</TD></TR><TR><TD CLASS="quote"> not if you know what your doing. </TD></TR></TABLE>
Ummm I do know what I'm doing. And yes it will leave some slag. Every try to cut through really thick plate? I suggest this because not everyone has alot of experience/PATIENCE to do some jobs. For this application a plasma cutter isn't a good solution and .040 cutoff wheel will do a better job.
Old Aug 18, 2004 | 08:10 AM
Finland's Avatar
"un-tigging" = cutting
There is no way to undo the weld with the TIG process because the base metal is melted...what was there is no longer there in the same exact condition as when the welding was initially performed...you'll just have to carefully cut/plasma cut the part off.
Old Aug 18, 2004 | 09:13 AM
jdmlife's Avatar
do not use a torch.. use a plama cutter or air arc it.
b16bri
Welding / Fabrication
Sep 10, 2010 03:15 PM
aleks77
Apr 8, 2007 03:04 PM
91integraLSVTEC
May 2, 2005 11:23 AM
pub
Mar 24, 2003 04:01 PM
curiousgpnoy
Jul 18, 2002 11:09 AM
